We just replaced the taillights on our trailer (2009 T@da) because they were very dim and we noticed that the turn signal were almost not visible. The new LED trailights work great but we discovered that when the lights are on the brakes and taillights work but there is an almost non discernible turn signal. When the lights are off all work as they should. Any thoughts?
2014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”
0 ·
We had a similar issue on our utility trailer. I followed the 4-pin cable back to the trailer's tongue, where I found the negative wire was screwed into the underside of the frame. The screw was badly rusted & most of the strands in the wire were broken. So, I cut it & stripped it back to good wire, soldered on a new loop connector, sanded all the rust from around the screw hole down to bare metal, then replaced the wire with a new screw and covered with dielectric grease. It worked like new.
Huntington LI
If you have a multimeter which measures resistance, it might be helpful to measure resistance between each plug & socket's ground contact and its respective trailer or vehicle's frame (using bare metal), to see if it indicates a good ground connection (a few Ohms or less) or a poor one (hundreds or thousands of Ohms). Also check the tail lights' ground connection(s) between the light & trailer's negative busbar's connection.
