Found this swivel clothes hanger on Amazon for about $12. Works great for hanging out the next day's clothes. Swivels out of the way when not in use. I drilled a small hole for a cotter pin and put a small piece of Velcro on the end to keep it from tapping against the sidewall during travel.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
Here is the link:
https://www.amazon.com/Newdora-Folding-Stainless-Clothing-Organizer/dp/B01LZ7FJ2C/ref=sr_1_27?keywords=swivel+chrome+clothes+hanger&qid=1559651994&s=gateway&sr=8-27
Similar models take four screws - their mounting plate may be too wide for the location on the valance. In order to get the most height from the seat cushion, it needs to be mounted as close to the ceiling as possible. This means the swivel arm must be in its slot before putting the screws into the wood. One nice thing about this location, is that clothes on a standard hanger don't impede access to the entry door.
Be careful not to mount the top screw too high such that your drill chuck rubs against the curved ceiling. Also, the cotter pin idea doesn't work that well because there is a lot of swivel to the arm. A better way to secure the arm would be to simply use a wire tie attached to the cargo netting (slip the wire tie over the end of the arm during travel).
T@bbey Road
Appleton, WI
Scott & the S.S. PorT@Bella
My Teardrop Mods https://georgianwinds.wixsite.com/teardropmods
