I have a T@B 400 that I have owned for all of one week. I am having some difficulty with the entry door lock. Initially, I found that the door would not completely latch and I could actually pull it open even though it was locked. When I inspected the lock, I found that the top striker bolt was very loose. The latch bolt appears to be deploying normally and the bottom striker bolt is tight. I was able to adjust the top striker bolt by hand and now the door seems to latch more fully (although there is some play remaining when I pull the handle while locked that causes the door to open about 1/2”) but the top striker bolt is still loose. I’m thinking there must be a nut inside the locking mechanism to snug the striker bolt that I can get to only by disassembling the locking mechanism. Has anyone done this? Is it difficult? It’s below freezing here and I’d rather not attempt the fix if there’s risk I’ll screw it up. Thanks for your assistance.
1 ·
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Central Alabama
Central Alabama
Regarding lock replacement, does not seem to be standard RV type lock that you can simply buy online or from Camping World (standard: latch extends outward from inside the door whereas the TAB 400 latch extends outward from the rear surface of the door)-- looks like a special lock will be required. Anyone have any experience in replacing the TAB 400 door lock?
2014 Toyota Sequoia
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
Could you post some photos pointing out the screws you reference. NuCamp sent me the repair kit they claimed would fix the problem but there were no instructions with it. The parts they sent didn't make much sense so I never installed the repair kit.
2013 Tundra TRD 5.7L
Massachusetts
Taking the screen door out is easy and allows fast access to the whole assembly. Three screws on each side of the screen door removes the whole assembly.
PNW
TV: 2017 Chevy Tahoe
