So, I've been trying to study up on the Zamp solar. I have the Zamp port factory installed. From what I see, the Zamp specific systems are significantly more pricey than something comparable from say Renogy. I would like to someday get a portable unit. Are there cables/connections/adapters that can be used to hook up a Renogy portable through the Zamp port or an adaptor for the trailer electrical/7 pin cable so I wouldn't have to hook up to the battery every time I use it? If I'm understanding what I'm researching, the Zamp uses different connectors than the Renogy uses? Zamp also is reverse polarized? I would not be comfortable with striping wire & splicing on a different connector. Is that the only way this can be done? WHY did they use this Zamp system?
2018 Tab 400
0 ·
Huntington LI
https://www.renogy.com/mc4-to-sae-adapter-12-awg-cable/
1. Renogy MC4 to SAE adapter https://www.amazon.com/dp/B01N1TALFY/?coliid=I2ZK1E27IGFFQA&colid=10JTC9Y710WAC&psc=1&ref_=lv_ov_lig_dp_it
2.
Tecmate Optimate Cable O-27, Adapter, Polarity, SAE
https://www.amazon.com/dp/B00AHCWGOO/?coliid=I35J3WTUBIMUOK&colid=10JTC9Y710WAC&psc=1&ref_=lv_ov_lig_dp_it2016 Nissan Frontier SV 4x4 Crew Cab
Thank you for the confirmation on what I have been trying to understand about solar, integrating it to work with the Zamp. I did not want to have to splice into any wiring or reverse any wiring, and really didn't care to use the alligator clips every time either.
Just want it to work like a plug-n-play since the port is already installed. I definitely will check the length on the cable, I don't think it's all that long. This is one of the few things that I am disappointed with on my little trailer. There are so many other options out there for solar and the Zamp systems are 2 to 3 times higher in price than some other options, not to mention the wiring reversal.
