Coroplast bottom cover (belly pan)
chpiv
Member Posts: 20
I have a 2015 320 Outback that has no covering on the bottom. I understand that later 2015s and subsequent years have this covering and in some posts on this forum this cover is shown when installing a high altitude kit. I would like to cover the bottom as I intend a long trip in December and wished to "somewhat" insulate the water tanks, holding tanks and water lines there. What I need to know is if anyone knows the true thickness. I have read 6mm but would like that confirmed if possible. As source in California would be nice as on line seems to just sell it 4 feet by 8 feet in pallets of 10.
Anyone who has a picture(s) of the portion in front of the axel would be also appreciated. I have pictures from the rear.
Thanks in advance!
(Title changed to allow for future search. - Moderator)
Thanks in advance!
2015 Little Guy T@B Outback
2017 Toyota Tacoma Offroad
Bishop, CA
Bishop, CA
The belly pan is just standard "Coroplast." Home Depot (at least enemy area) sells it although I have not seen any colors other than white. You can probably find other colors at a sign shop--ones that make political signs.0
Thanks for the reply. I have been away from my computer for a little while. I have looked at Home Depot and at least on line (it is over two hours away from my home) it comes in 10 sheet pallets. It is also .157 in thickness. In this forum somewhere I have read someone believed it to be 6 mm which is about .236 in thickness. I am looking for a sign supply shop or a big sign shop in the Reno area to see if they have it. There should be plenty of political signs coming up!!!2015 Little Guy T@B Outback
Bishop, CA0 -
Just happen to have mine off the frame. It's 49" wide by 76" long. It is thinner than the Coroplast available at Home Depot (in white only). You can get by with 48" wide.
2024 Ford F150 Supercrew short bed.3 -
Thanks, that is just what I needed! Love this foru2015 Little Guy T@B Outback
Bishop, CA0 -
"Coroplast".. Isn't that the organelle which distinguishes a plant cell from an animal cell? 😉-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods1 -
Yes. They now make campaign signs out of it.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
Chloroplast @BrianZ- close, no cigar😊Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Just curious if anyone has tried to insulate the tanks on a 400? I am planning on a December trip and was curious if it is possible to upgrade to a season 3 ranking to withstand temps in the upper 20s to 30 degree kind of Fall temperatures??0
@mikesnewjourney with temps in the 20s and 30s you'd probably be good with just adding some heating pads on the tanks and most importantly the dump valves. However if you drop the belly pan to do that you might as well insulate as well. Here is a thread from someone who added 12v heat pads and insulation to the underbelly.
https://tab-rv.vanillacommunity.com/discussion/12589/2021-nucamp-t-b-400-boondock-winterproofing-instead-of-winterizing#latest
2021 T@b 400 BD "Vixen Gail"
Leadville Colorado2 -
I had 12v heating pads added to the fresh water and the grey water tank added by the dealer. They said not to put a heating pad on the black tank but you can use Rv antifreeze to flush in freezing temps. Heating the black tank may give you bad smells. Not sure you use the toilet, just thought I would mention it.0
@mikesnewjourney Look over these threads and a couple of owners have tackled this. https://www.google.com/search?q=heated+tanks+site:tab-rv.vanillacommunity.com&client=firefox-b-1-d&sca_esv=591244276&sxsrf=AM9HkKnPzVsWyPodDn7FwoUdKU-xwz59Ew:1702659856995&ei=EId8ZdWrPOyIkPIP6vSaiAY&ved=0ahUKEwjV88uf9pGDAxVsBEQIHWq6BmEQ4dUDCBA&uact=5&oq=heated+tanks+site:tab-rv.vanillacommunity.com&gs_lp=Egxnd3Mtd2l6LXNlcnAiLWhlYXRlZCB0YW5rcyBzaXRlOnRhYi1ydi52YW5pbGxhY29tbXVuaXR5LmNvbUiEOVDECVjsNnACeACQAQCYAUWgAcUKqgECMje4AQPIAQD4AQHiAwQYASBBiAYB&sclient=gws-wiz-serp
I have a 2020 400 unit and I am in 0-20 degree weather for 6 weeks before heading down to Florida for the winter. I've never had anything freeze underneath, but I do keep the water tank full daily and I use the water throughout the day. The biggest thing in cold weather will be not having a hose connected and using a few small fans inside, to circulate the air to prevent moisture buildup on the walls.
Full-time rving since 2006, tab owner since 20221
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
