First let me start by saying I like the jack wheel, and don't want to get rid of it. I'm not the greatest at backing into sites and the wheel helps in getting into tight spots.
So I get hooked up to my truck, 2006 RAM 1500, raise the jack, remove the wheel, and after a safety check I'm on my way. We traveled about 70 miles, about an hour and 45 minutes. Roads were fairly decent, typical bumps and holes.
Got to the site, tried to attach the wheel, and I couldn't get it under the jack. I was lacking maybe a 1/2 of clearance. I was able to get it on by unhitching and lifting the hitch while my wife got the wheel on. Wasn't the easiest thing to do, both the lifting and her fitting it on.
So for the experts out there, what happened?
Are my springs starting to give out and sag from the T@B weight?
When we got back home I was able to get it on, but just barely.
We did have a little less weight in the truck bed on the way back home.
Tampa FL
0 ·
I'm basing that on your clue: "When we got back home I was able to get it on, but just barely."
Hitting potholes while towing, or just the passage of time, can occasionally wreak havoc on the tow hardware. If some of the bolts holding it to the frame came loose (were never fully torqued with loctite by whoever originally put the tow kit on), or the welds connecting the receiver to the towbar, or towbar to frame brackets failed or are failing, or if you just have stress cracks... then the standard jack wheel can no longer fit, or just barely fits, when everything was normal on the previous trip.
I didn't notice the front of the 320 riding lower when this happened to my tow vehicle a year ago; I DID notice the jack wheel didn't fit as well, and started to wonder why.
Hopefully that's not what your issue is, but it is a big safety issue if it is.
When we occasionally want the wheel to move around and there isn't enough clearance to mount it, the routine is to lower the bare jack enough to unhitch, lower the front stabilizers, raise the jack, install the wheel, lower the jack, raise the stabilizers a bit, maneuver the T@B into position, then level.
I'm not into dead lifting 200 lbs any more.
Tampa FL
Tampa FL
Tampa FL
Tampa FL
Tampa FL
Also Documented.
Tampa FL
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
