Hey folks. I was curious... do any of you use a small, portable space heater to get up to sixty or so more quickly, then kick the Alde in?
I was concerned about safety, and if it is common to do this, which heaters are compact, cool to the touch, have tip-over shut-off, and bring the temp up quickly. Thanks!
T@B 400 2020
0 ·
2013 Tundra TRD 5.7L
Massachusetts
2011 T@B
Rockingham, NC
Odessa, Fl.
1. Honeywell 170W / 250W. $26
Very quiet, very small, low power, but very simple (no thermostat).
https://www.amazon.com/dp/B00NXZ7UMA
2. Life Smart 350W. $30
A little bigger but still small, a little louder, starts up at 700W whenever the thermostat kicks it on, but settles down to a stable 350W, uses a cord or plugs into wall, has remote and timer and thermostat (but only goes down to 60F).
https://www.amazon.com/dp/B07VPD8ZF7
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
Keep in mind that the Mr. Buddy heater (if that is what you have) is propane operated and will need combustion air. If you run it in an enclosed trailer with no ventilation you could have greater problems than a chilly camper. I have found that the Alde system (on propane or electric) warms the trailer up pretty quickly. If you turn it on as soon as you park at your campsite it will have the trailer warm by the time you finish setting up.
If you have a CoolCat unit in your trailer use the heat pump setting and it will start blowing warm air into the cabin almost immediately.
Had I only used the Alde alone, which I had been doing previously up to this point, it would have taken several hours to get to 65F. Granted, I was in driveway so plugged into a standard outlet and Alde on the "1" setting so not sure if setting "2" generates more heat. Will have to test that next time at a campsite when plugged in to 30A.
Don't think I mentioned earlier, but I chose the Buddy heater over an electric heater because I always get nervous of plugging in space heaters due to the power draw, whether it be at home, work, etc. Plus, I like the idea of getting heat without electricity if needed, whether it be in camper or elsewhere.
