Just picked up our new 320s , and noticed that the Alde 3020 display could possibly be set up to register an external temperature reading on the display ? Thinking that would be a very nice feature to have ! Surprised nuCamp doesnt include as standard with the Alde system .
So .........
Has anyone added the external temp sensor to there tab with the Alde system ? Is this even possible / sensor available for purchase ?
Thanks for any info !
2024 NuCamp T@B 400 BD, Charcoal / White
0 ·
I am going to try and see if my dealer can order this for me .
Will report back on how that goes , and installation if I get that far .
Thanks !
Also, do you happen to have the nuCamp part # for the Alde Temp sensor ?
Cost was around $25 from dealer.
Any chance of getting some photos of the connection at the other end too? ie in the Alde compartment?
I am a bit nervous about drilling through floor and wondering how you selected the location? Did you drill top down from inside the Alde compartment?
How has the Gorilla tape lasted?
Thanks in advance.
Do you know how long the batteries (looks like 2 AA) in the battery backup last?
I looked into this sensor months ago, but couldn't determine if it actually used the data to more intelligently warm the interior?
2024 T@g 5-wide Black Canyon
I asked Spencer at Alde about the temp sensor and he said it simply tells you the temp at a location other than at the Alde display panel--and displays it on the panel. You can connect up to two separate sensors.
