It got cold here last week so I thought it was a good time to test my heat using propane. The Alde worked just fine. Took about an hour to heat from 25 degrees ambient temp to 72 degrees inside temp. I never heard as much noise from the Alde as some here have indicated. As a matter of fact, the only way I could really tell that the Alde was working was to check the exhaust port for warm air.
However, after I shut everything down I noticed that the exhaust port was covered with black soot. This indicates incomplete combustion, no? Have any of you noticed this? Is there some adjustment I need to make to the Alde heater? I am at about 1700 feet above sea level so I doubt it is an altitude issue. Since this was the first time I ran the Alde with propane and I have only run it on electric once I wonder if this is just stuff burning off of new materials.
Any thoughts?
0 ·
Mine is probably an outlier data point for 99% of you (and no, I did not have hookups)... lol
2024 T@g 5-wide Black Canyon
I cleaned the soot off and ran the system again the next day--no soot deposit at all! The OAT was about 25 degrees warmer the second time but I'm at a loss as to how that would affect the system.
I did notice that the hot exhaust air is directed out at the 3 and 9 o'clock positions behind the white cover. Alde told me that the intake air runs through a hose INSIDE the exhaust air hose. Therefore it is drawing combustion air around the white cap with the Alda label on the front. Now I am really stumped.
BTW I am at 1700' MSL here and the high altitude setting was off both times.
http://forums.outandaboutlive.co.uk/forums/Motorhomes/Motorhome-Matters/Alde-3010-problem/37241/
I almost always have some minor amount of black soot when using propane at home base at just over 6000 feet. I thought that it was normal since the Alde was heating properly.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
The high altitude mode is NOT automatic. It must be selected through the "gear" (I don't remember what the correct Alde term for that is) icon. From what I understand from Alde, the high altitude mode increases combustion air by using a fan to push more air to the burner.
Just talked to Spencer at Alde US. He told me that the exhaust air exits through the center of the external port (logical since that is where the soot was) and the intake air enters from around the sides of that port right next to the trailer wall. That makes a lot more sense than what I understood before. Still, the question remains: why was I feeling hot air exiting the port next to the trailer wall?
I guess I will wander outside with a screwdriver and see if the intake and exhaust hoses are tightly and properly connected.
On a related note Spencer told me that the office in the PNW will close at Thanksgiving and all Alde activity will move to Truma in Elkhart, IN.
2018 T@b 400
2019 Ram 1500 crew cab / 5.7 V8
I do wonder if they merging service and parts here in the North America market? It would appear so, but not sure what this means long term.
I will check next time I'm over there.
I wonder if it would be a huge design change for Alde to install some no-volatile RAM on the circuit board. Maybe that will come with the 3030 model.
2012 Jeep Liberty KK a/k/a "Libby"
