ELK
Member Posts: 213
Hi all. I'm in the middle of winterizing....blew out the taps, closed the valves for winterizing, poured 2 gallons of diluted pink anti-freeze into the fresh water tank....turned on the water pump....and I'm getting nothing. I waited at least an hour and still nothing. The water pump is working and things are gurgling....but nothing comes out of any of the taps or the flushed toilet.
I DID open my cold water drain valve (under the seat with the blue and red pipes) and drained it....could that be a problem? Seems unlikely.
How long does it take to pressurize?! Thanks
Should taps be open or closed when pressurizing...mine have been closed.
