A much better idea!
With the two T@B’s I have had, on the first one a 2016 CS the Lagun table top would fit perfectly across the area where the bed slats go. I would use it instead of 2 or 3 bed slats. On the second 2018 I bought, the Lagun table was just a little bit shorter so it could not be used as a bed slat. Now that NuCamp has the newer and lighter Lagun table tops wouldn’t it be great if they made the Lagun table top the correct length to be used as a large bed slat and have 2 more thinner ones that could be held by magnets or some other way mounted under the Lagun table edges? That way they could do away with the bed slats all together. Art
2019 TaB 320 S Boondock Edge
