A much better idea!
gulfarea
Member Posts: 524
With the two T@B’s I have had, on the first one a 2016 CS the Lagun table top would fit perfectly across the area where the bed slats go. I would use it instead of 2 or 3 bed slats. On the second 2018 I bought, the Lagun table was just a little bit shorter so it could not be used as a bed slat. Now that NuCamp has the newer and lighter Lagun table tops wouldn’t it be great if they made the Lagun table top the correct length to be used as a large bed slat and have 2 more thinner ones that could be held by magnets or some other way mounted under the Lagun table edges? That way they could do away with the bed slats all together. Art
2019 TaB 320 S Boondock Edge
I made a top that can do that. Simplifies things a bit.2017 T@B Max-S, silver & silver, towed by a Titanium Silver 2018 Kia Sorento AWD V-6, Twin Cities MN
GibW I thought about making one up also but liked hearing about NuCamps lighter top material. Art2019 TaB 320 S Boondock Edge
I'll have to add "make a combination Lagun table top/bed slat" to my to do list. I always found it a pain to store the table top on the floor under the bed slats at night when making the bed. My Lagun table top screws attaching it to the aluminum plate striped out of the table core material which is appears to be only particle board. Had to repair it while traveling.2019 T@B 320S
We put our Lagun table on our outside mount under our side tent. Keeps it off the floor. We have also covered it if the tent is not in use.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 919 Introductions
- 74 Teardrop Groups & Links
