Thanks
qhumberd
Moderator
tab leveling question?
doe's the 320 have to be completely level for the alde to run heat on driveway on shore power? thanks :) it's close.
2018- 400- Colorado V6-Marin MT bikes :)
    edited November 2019
    No.  The Alde will run regardless of level, however, your frig must be level when running on LPG.  Lucky you, I do not think the new Air 8 A/C unit requires any kind of drain system, so no need to position the TaB nose down like the window style A/C units.
  • boonie
    boonie Member Posts: 83
    thanks sharon, this is just for temporary heat this winter in our driveway as we become familiar with our tab :)
  • Tundra57
    Tundra57 Member Posts: 640
    Funnily enough, my 2019 tab 400 has the front mount ac. I ran it in 90 plus degrees and it kept the inside below 65 easily. It has a drain pipe running from under the trailer and it dripped like a window AC. The trailer was level and everything worked fine. Never had to "lean" the trailer.
  • 4ncar
    4ncar Member Posts: 1,072
    The “lean” technique only applies, really, to the 2019 and older 320S with the Danby window style AC unit.
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    @Tundra57 are sure there was a drain pipe? My 2019 400 with front ac just Cascades over the edge out of the drip pan. I have found no drain, maybe they didn't install one?
  • Verna
    Verna Member Posts: 6,876
    There is no drain tube on the Cool Cat A/C units in the 2019 T@B 400’s.They have a tray that the condensation drips onto and then it drains/drips through the grill to the outside.
  • Tundra57
    Well mine must have been modified. I was going to fit one till I took off the grill and saw the tube fitted. I ran the AC and sure enough the tray filled and ran down a clear tube drilled through the floor to the outside. I thought it was a standard Nucamp mod. The grill outside was well sealed around the edge and appears to have not been removed until I did. Wierd!
