My 1 1/4" shank receiver is approx 14.5" from ground to top of receiver. Bottom of hitch opening on trailer is just under 16" from ground. Does a 1.25" delta make a significant difference? Doesn't seem worth it as a 2" rise would put me 3/4" over...chasing my tail?
San Diego, CA
www.airbossone.comhttps://fineartamerica.com/profiles/owen-ashurst/shop
0 ·
San Diego, CA
www.airbossone.com
- - - Expect you will have Tow Vehicle rear sag. - - -
So I would start with a 2 inch rise [[ C ]] drawbar.
Adventures: 55 Nights: 376 Towing Miles 46,920
https://www.mclaughlinvolvo.com/research/xc40-xc60-xc90-towing-capacity.htm
I was curious about the hitch too. I'd only seen smaller than 2" receivers used for bike / storage racks, though theoretically a Class II is good for up to 300 / 3500 lbs. But a 2020 400 tongue weight is 380-400 lbs, right? Not 300 lbs typical of a Class II. There are always exceptions though.
Took the day visit highly-regarded trailer supply shop here in San Diego (been around since 1948). They were kind enough to loan me a cool tongue weight gauge device after investigating my TV (2019 Volvo XC 60 T6) and the hitch (OEM retractable hitch/ 3500/350). Then went to T@B dealer. They are completing accessory installs. Tongue weight on my trailer (with box and propane tanks installed) came in at +/- 325lbs (checked it 5 times with no variance). Took a spin around the lot with dealer walking with me while I went "hard over" on the wheel taking sharp turns. The new box (super light-weight but larger than I anticipated) came a bit too close to TV for my comfort so back to supply shop for a short hitch extender so I have a bit more clearance in sharp turns. May trim down the box (45 the corners, etc.) at some point as well. Configuration looks about right front to back.
TV performed as expected. Automatic sway control engaged and vehicle ride height adjusted automatically, and it ran a vehicle/trailer check for bulbs, etc. All good. Will run further checks.
So, picking it up Saturday, then back to supply shop to install Prodigy RF Brake System before towing to storage facility. Unfortunately I'm leaving town for a week on Sunday so won't be able to do much with/to the new rig until I return. Argh...it's killin' me!
Thanks again for chiming in here and on other threads as I get up to speed. Learning curve is steep but enjoyable and I appreciate hearing from folks on this forum. Shake down cruises await...
San Diego, CA
www.airbossone.com
Ouch! That looks painful. Hope it didn't leave you stranded. Obviously with my TV I'm not going to be doing much that can be regarded as off-roading or trekking on unimproved roads. Find a nice place to boondock without jeopardizing the ride, perhaps. Finding a mountain road to get lost on for a week...not so much.
Go the TV couple months ago and while I did make note of the towing capabilites, it wasn't my priority. And since I don't anticipate spending the majority of my time towing, I wanted a vehicle that had all the creature comforts one could want but could also tow a teardrop cross-country. Hopefully, that's what I found. Time will tell.
Thanks again for your input. Always appreciated...regardless of whether it's cautionary or complimentary.
Cheers!
San Diego, CA
www.airbossone.com
Do keep in mind [ A ] the XC60 is not designed for towing, [ B ] you will be towing at near 100% of the USA rating + at a higher percentage of maximum tongue weight, and [ C ] Volvo says to reduce your tow rating by 10% every 1000m of elevation (typical for gasoline engines).
The 'take away is' Drive Slow. 65 MPH max at sealevel {55 in California
Yep, I'm aware that the XC60 is not a RAM 3500 by any stretch (owned one years ago with 3-horse trailer...it was a beast)! That said, Volvo is by almost all acounts a superior engineered product that has provided for OEM towing capabilities. They purposefuly designed the vehicle to tow to 3500lbs (by most acounts beyond that but I'm not intending to push that), designed the OEM hitch to do so, and on-board software (Trailer Stability Assist and Electronic Control System) coupled with Prodigy RF Trailer Brake System provides a level of comfort that, provided I don't do something really stupid, should treat me well.
And yep...I'm aware that I may be pushin the envelope a bit RE: some of the parameters. Onboard systems are constantly monitoring vehicle performance (including all temps, pressures, ride height, etc.). To your point (and it's a good one that I've investigated), Volvo mentions the reduction of limitations above 3300'MSL. I'll be watching that carefully as well. That said, since I have no plans at this point to take on "Going to the Sun Road" or "Independence Pass" I'm fairly confident I'll be OK.
All good points, Chops! Good stuff, indeed and much appreciated!
San Diego, CA
www.airbossone.com
Odessa, Fl.
While the towing capacity of the 2019 XC60 is 3500lbs, and it has HUGE brakes, I think the maximum tongue weight is listed as 110kg (242lbs) in the manual.
2016 Max S, 2011 Volvo XC60
So I had to borrow DW's SUV to bring the camper from Austin home to D/FW. That was 60,000 miles ago and a hundred successful mountain passes ago.
I ended up having to learning to weld, in order to repair and strengthen my hitch setup. But thanks to that isolated hitch problem, I picked up a valuable skill with which to fabricate all sorts of kewl mod ideas I get from this supportive forum.
I think you will be over weight for a class ii hitch regardless of tow ratings Volvo published.
I have a 2019 400 and do realize they shuffled stuff around to get a lighter hitch weight for 2020 models,but I would not pull my 400 with anything that wasn't rated for at least 500/5000. I pull with a full size Ram but not a dually like you had. I still know there is a trailer back there, especially pulling grades.
You might prove us wrong on the capablties of the Volvo as far as performance, but I think you are borderline on the legalities of doing so with that class ii hitch and that is a concern not only for you but every other motorist on the road with you.
That being said I think you'll be fine -- with a 320, not a 400.
You might want to contact etrailer.com and ask what they think. They have experience with Volvo's.
Keep in mind 3500 lbs is TOTAL capacity including trailer, gear in TV and trailer, and passenger weight.
IMO for the long haul trip you're planning the X60 (3500 lbs) is a fine match for a 320, but for the 400 you'd want an X90 (4000-6000 lbs) with a Class III hitch. Even then you'd get some flack from the truck crowd here.
That said, and with complete recognition of the limitations of the TV which I knew going into all this, I'm looking into a gently used P/U for tow vehicle.
Last thing I want to do is put the Volvo in jeopardy long-term...but even more, any possible impact ( no pun intended) on fellow travellers.
Time will tell. Short trip/shake down cruise from 26-29Dec. That will go a long way in making up my mind.
Appreciate the spirit and feedback, folks. Exactly why I joined this forum. Travel safe everyone and Merry Christmas to All!
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
After investigation I bought a Tekonsha prodigy rf brake controller. However, I discovered that the dealer installed 7 way connector did not have 12v power connected. The Tekonsha folks said the prodigy requires 12v from the Volvo. The Volvo folks say the alternators don’t put out enough juice to power anything extra. That’s why, they say, they don’t provide power to the 7 way plug.
Clearly many folks use Volvos for modest towing like my 320. What’s your experience? @AirBoss and @N7SHG_Ham any wiring issues? Thanks.
2018 Toyota 4Runner
Bowdoinham, Maine
I am amazed that Volvo rates a vehicle for towing where the alternator is so overwhelmed by a small trailer.
One of the things that grinds my gears is manufacturers rating something to tow that really can't and I think they primarily do that to sell vehicles. Everybody wants to tow, so let's say we can, grrrr
Boy, the things you learn!
thanks for the suggestions. I’d still like to hear if anyone towing with a Volvo has had any problems.
2018 Toyota 4Runner
Bowdoinham, Maine
Was told by Volvo Service Mgr. the vehicle can handle the electrical requirements w/o difficulty. As for towing the 400, it would not be best.
I made the decision to purchase the Tahoe Z71 as the TV as the Volvo would likely have been over-taxed.
San Diego, CA
www.airbossone.com
2018 Toyota 4Runner
Bowdoinham, Maine
Did you install the Volvo fully integrated drop-down hitch?
San Diego, CA
www.airbossone.com
