Yo, people— I have just now overfilled glycol tank by about an inch
Tonyb
Member Posts: 2
any anyone know if one can buy a small syphon ?0
A turkey baster would work.2016 Outback 320
2024 Ford F150 Supercrew short bed.2 -
+1 for the turkey baster. Been there done that.Can be a little messy, so use rags around it.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
you can remove the plug under the trailer and reapply after draining some off.2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
aka BirdieJane towed by Quinn0 -
A syringe would work as well20 T@G XL Boondock and 2019 Ford F 150 4x4
Madison, Wi0 -
Probably no damage will result, but it might slop out and or go out the overflow tube.2019 T@B 400 Boondock Lite0
I agree with @N7SHG_Ham. The system is not under pressure so the only concern with overfilling would be an increased risk of spillage. Even at the proper level, that tends to happen when you go bumping down the road.
My glycol tank level goes up when it gets hot. Normal. So if overfilled sufficiently, then run for a while, some could leak and some could go out overflow tube.2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
When you say "by about an inch" do you mean an inch over the proper fill level (about 1/2' above the min mark) or an inch above the max mark? The glycol will expand (and you will see some turbulence in the top of the tank) when it heats up. If you have not left enough room for that expansion the excess glycol will leave the system through the overflow tube. Eventually you will end up with the proper glycol level--and a mess under the trailer maybe.0
Turkey baster worked for me when I did the same thing.0
