I am the new guy who just recently purchased a TAB 320S Boondock Edge.  I live in Utah and the winter weather will soon be upon us.  I want to store my new little baby in our garage but it is only 93" high and the TAB trailer is 98" high.  Do you think I can let 5" worth of air out of my tires, roll the TAB into the garage, and the put the air in again?  Your thoughts and expertise would be greatly appreciated!!!
                0 ·
If you bought a couple of the lowest possible profile tires from your local tire shop that would fit that baby rim you ought to be able to make it, as long as that doesn't scrape your tank drains. Or just go without the tires and roll it into the garage on those new inexpensive baby rims.
Not sure if you'll quite make 5" with deflation alone.
Lil_Lucy back in 2015 posted here: "Yes. I removed the 14" tires and wheels and replaced them with 12" rims (no tires) then just pushed it into the garage. It's a real close fit. The rubber door seal on the garage door header just skims over the A/C fan vent cover but I didn't have to remove anything on the top. I would suggest to anyone to MEASURE, MEASURE, MEASURE before you attempt this in your garage. Height clearances could vary and there is no room for error. There was no dolly involved."
So you may be able to go with a bigger rim, like a 10" or 12". Using the search feature for the forum on the top right of the screen with "garage clearance" I found pics of triumph...
let the air out of tires ha ha
2019 Jeep GC 5.7L
and two furry bed hogs
Colorado
I'm not quite sure what the height will be with the 8" tires yet-they'll arrive tomorrow. I may have to let some air out of the tires or even remove the tires and use the rims only to get the Boondock in the garage. I'll post more as time move along....
Huntington LI
Huntington LI
I have a 2020 320s Boondock Edge. I have 7 1/2 foot high garage door openings. The exact measurement for my third door is 88" vertically to the middle of the flexible vinyl seal. I cut and stuffed two 2x4's for the left and right edges of the door to raise the door totally above the vinyl seal.
I bought two 10x6 rims off ebay ($33 ea. they were "take-offs".) 5 hole on 4.5" circle. They measure 11 5/16" maximum diameter. I cut off the inside rim with my angle grinder so that they would clear the brake hub. Interestingly, the rims would not slide on my lugs. So I cleaned up the lug holes with a 1/2" drill bit. Still not big enough. I went up one 64th to 33/64ths. That was perfect. When I got the trailer on the ground I saw that the brake drum was way too close to the concrete. So I cut some 1/4" plywood strips to roll the modified rim upon. That worked just fine. I backed in the trailer with my DW checking clearances constantly. I can report that we didn't touch the vinyl top seal of the door, we didn't come within an inch of it, I believe. So that means I could have bought 12" rims and would have still cleared. When I roll it out, I will use thicker plywood.
With the Boondock tires on, I believe my trailer is 94 11/16" to the high point on the stock vent. (The BD Edge lightbar mounts are 1/2" lower in elevation than that.) With the 10" wheels on, my trailer is about 86 to 86 1/2" tall.
2020 T@B 320 S Boondock Edge, 2020 Subaru Outback
I want to correct one thing I said earlier about the height of my trailer on the 10" rims. I just went out and measured the height: Measured 87" on the right and 87 1/4" on the left. This is with the rims sitting on about 1/8" of plywood (crushed 1/4" plywood).
So the small rims lowered my trailer 7 7/16". A regular 320 will not be this much, the fatty tires on the boondock is why, of course. I was previously estimating the radius of the Boondock tire and wheel was 8", and guessed how much tire squish I might have. Looks like 9/16", maybe.
My trailer will now happily sitting in the garage for five months.
Good luck Dave and to everyone else.
2022 Honda Ridgeline RTL-E
Carmel, IN
And @RVMike, my good fortune is my brother has access to a CNC type cutting machine so the location of the holes is all programmed in advance. I wouldn't even think about that much effort if it weren't for the contact.
