Unintentional front wall modification
db_cooper
Member Posts: 749
Looks like I'm going to do a mod to the front wall above the sink on either side of the window.
I had put some clear helicopter tape around the window as a temporary fix for mosquitos getting in. While installing the new no-see-em covers I sewed, I removed the tape, only to remove the faux wood paper veneer around the window. Be advised it is a very thin paper, probably heat bonded to luan or the adzel if they use it there. I found others have pulled it off with painters tape, so it is very easy to damage.
I'm thinking of maybe 3d printing a silverware holder on the right lower side, and cellphone holder on the left lower side, matching the curve of the wall. They may look very similar.
Most of the damage is above the wood strip in the middle of the panel, so I'll probably get some contact paper to cover. Haven't found any I like so far with teardrops or outdoors/woodsy pattern. Has anyone put contact paper over the faux wood, and found a pattern that looks good?
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620
Ouch! I don’t know why you couldn’t use contact paper. A lot of people use the lightweight stick on tiles, I think they’re plastic, on the kitchen walls to change the look. You could look into those. As far as attaching something to the wall that might hold something heavy you may want to rethink that. Here is a picture of the Tab walls.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0 -
@db_cooper I have seen several really nice mods on the kitchen walls with the peel & stick tiles. For myself at least, I don't trust that I could get contact paper square or not have wrinkles/bubbles, but I think the squares would be doable as long as one took their time and paid attention to detail. . ..2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0 -
I recently put up faux shiplap (inside) and faux subway tile (CS kitchen) using peel /stick/reposition wallpaper on the walls that are not the faux wood. Give yourself tons of time, have patience, measure twice, cut once. It truly is repositionable. I am very , very happy with the result. It would be an easy, affordable, very lightweight & attractive solution to add to the entire front panel, think of it as an enhancement!
3 -
Can u tell me what wallpaper you used ?
thanks Palmer2019 320S Boondock Edge0 -
@Tater, I stumbled upon this response from @COcamper inadvertently posted on the "Activity" page, so I cut and pasted it here for you:
COcamperHi, I used 2 different peel and stick. I was very happy with the usability of the shiplap paper from Walmart, NuWallpaper brand. It was very forgiving.
The subway tile paper from Target was "Devine color by Valspar' and extremely frustrating to work with.9:06AM2019 T@B 320 S Boondock Lite ~ 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ)1 -
wow...Thank you so much for finding that info.2019 320S Boondock Edge0
