Tab 400 roof insulation
Tundra57
Member Posts: 640
I believe the roof of my tab is the same as the floor with one inch of foam insulation. Since the roof is a major source of heat in both directions, anyone thought of adding a false ceiling inside to add another inch or so of insulation?
It's the biggest source of heat in the summer for sure (based on when I had a working thermal camera). Even winter camping, once the sun hits the roof I can feel the warm spots on the roof every 10" or so as the aluminum framing conducts the warmth inward.
If you used a series of 4" foam strips, would you try to use a birch laminate on each strip? Go for another color / texture wood? Cover the whole ceiling with a high resolution night sky or Sistene chapel mural? Plaster it?2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
When we were at Assateague this past July, we put a 10 x 10 canopy over the TaB. It helped and it cooled down at night.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Canopy might work if it will allow sunlight for my solar panels.I like the sistene chapel mural lol.0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
