Thanks, I need K experiment a little more but what you describe sands better.PXLated said:Don't have a good enough connect to watch the vid but never run mine on propane when on the road anyway.
Jenn - Ice seems like such a pain - On short trips (2-3hrs) I run it on battery and have never had a problem. For longer (6-8hrs) I alternate on/off and everything stays nice and cold. I think I've actually done a 6hr on battery with no problem but I started alternating because of your problem.
If I did have to use ice I think I'd just pull out my collapsible cooler and put stuff in there for the trip.
This looks promising and makes sense. Make sure you take picks or video if you do the mod. It will void your warranty, so that's my only hesitation.ChanW said:Jenn, there's a fairly simple mod described in the link below that adds thermostat control to the 12v mode of the Norcold 3-way.
Here: http://www.rialtainfo.com/model_info/modifications/refrigerator.htm
Once the fridge is up to temp, it would only come on now and then, and thus drawing less power form your TV's system.
If you're not comfortable with electrical work, you could get your local friendly geek to do it.
After having drained the Tab battery two or three times last trip, by forgetting to switch it off when parked, I've ordered the parts for this mod, and I'll let you know how it goes. (Luckily we have an isolator protecting the TV's battery.)
That is the point of the video, gas turned off stops the flow in the 4 branch lines in a standard RV propane system.leenscottfl said:This thread is about the wisdom of operating the fridge on LP while traveling. Seems that the main problem is the fire danger in case of an accident. It may be simplistic to point it out but I have to say that the real danger has nothing to do with the fridge but rather the fact that the gas valve must be left open. Turn the gas off when driving to eliminate the danger.
Trueleenscottfl said:I know but it doesn't hurt to state the obvious sometime.
Marvin at the factory seemed to think it drew more than that. The other possible solution might be to find a way to mount my little 10watt trickle charger to the battery box cover, flat. The panel has slots on the sides, so you could run a strap through them.ChanW said:Jenn, the 3-way draws 11 amps. (edit) I'd think a high output alternator could handle that.
If in doubt about the capacity of your alternator, you could find an alternator/generator rebuild shop, and ask them to look it over. If it's a problem, they could likely set you up with one with a higher capacity pretty easily. And the cost shouldn't be too bad.
ChanW said:10 watts is only @ .830 amps at 12V. That wouldn't do much for the fridge.
That's interesting to know, from Marvin. I thought he Norcold specs said 11A. I'll have to measure it.
Our Tacoma, which has the standard, not high output, alternator, puts out between 60 and 90 amps, from what I've been able to gather. A higher output alternator would put out at least 120A.
That could be it. I had the dealer install a transmission cooler when I first bought my Jeep. If I remember correctly, I measured around 11.83 from the 7 pin connector.PXLated said:Jenn - "often the "towing package" will include a high output alternator" - You mentioned you installed your hitch yourself. This could be the difference in your experience and mine. I have the factory package and don't have the problems you've had.
