I @kidware - When you mounted the Ikea shelf/spice rack, did you have to use wall anchors? I want to add this shelf and it looks like it matches the decor perfectly (I too have stainless steel sink area).kidware said:
I replaced the outlet over the stove with one that has two AC plugs and two USB ports (got the outlet at Lowe's) and added a shelf from IKEA to hold stuff.
You could also put it upside down with the ports facing out instead of towards the wall.Amazonica said:Wonderful! I think that might work, there is room for the extra bottom bit. Thank you!
I suppose the cigarette lighter adapter style usb outlets draw a little to run the little led indicator lights but how much draw are we talking? And you can always pull them out when not in use.ChanW said:The problem I've seen with USB ports that are powered off 12v (cigarette lighters, for example) is that they draw power even when not being used.
Not sure if that applies to all of them, but you'd want to confirm that, for battery conservation. Or maybe put a switch in line.
Marceline said:I suppose the cigarette lighter adapter style usb outlets draw a little to run the little led indicator lights but how much draw are we talking? And you can always pull them out when not in use.ChanW said:The problem I've seen with USB ports that are powered off 12v (cigarette lighters, for example) is that they draw power even when not being used.
