Light won’t turn off
Tchrdude
Member Posts: 6
2016 CSS. Light above front bench will not turn off. It will go from dim to bright. I have pulled the fuse (no joy) and tried holding the button down (also, no joy). How do I go about replacing it?
Help
Have you tried holding it down/in for several seconds?John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
Try the button a second time. I discovered by accident that mine has two brightness settings, so I have to press it twice to turn it off. Hope this helps!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
I found the replacement part but I can’t find anyplace that sells it. Dreamlight p/n 13603c.
Amazon. I Googled the part number, several places carry it. Ebay and Walmart, too.
@Tchrdude, here's the Amazon link to the page @Sharon_is_SAM posted above. I wanted to take a look at it, but It took me a while to find it. Couldn't locate it with the part number only, but did find it with the manufacturer name ("Dream Lighting.") Figured I would add the link to save you some time.
https://www.amazon.com/Dream-Lighting-Under-Cabinet-Switch-Motorhome/dp/B00WWDRGW8/ref=sr_1_28?keywords=myrvaccessories+dream+lighting&qid=1580568326&sr=8-28
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
Sharon and Bayliss, thank you very much.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
