see? There's a solution to every problem! (With a big enough truck!)
DougH said:But a cheap 120V flux core welder fits easily with a 20A generator in the back of a 1 ton long bed. After a few on the road frame repairs and 10lbs worth of fresh 75kpsi steel on the weak points it'd be set for anything but rock climbing?
3/4 Ton refers specifically to the payload (1,500lbs), nothing else. It is a somewhat antiquated notion, as my Honda Ridgeline has a payload just over 1,500lbs and is a unibody mid-size truck.BrianZ said:Please correct me if I'm wrong, but 3/4 is not meant as a fraction, but refers to a truck with a GVWR of 6000 to 8000 lbs (3 or 4 tons, like a Ford F150 I believe). The next class of truck capacity would be the 8000 to 10,000 GVWR, or 4 to 5 tons (presumably, this should be referred to as a "4/5 ton" truck, but seems to be called a "1-ton" truck; and would include those 250/2500 models).
Sharon_is_SAM said:Brian, you’re not alone - I had to Google it☺️ Also, my DH and brother-in-law, both with Doctorates, took hours to figure out how to reset the clock in our old Camry!
