I don't think that there much out there on the market in the way of 12v all-in-one units with a bluray player. Maybe because of the shift to streaming services.AirBoss said:
NITS:
OK, not really bad in the grand scheme of things but had to keep the Clint Eastwood theme going. I'm a bit of an audiophile and found the Jensen unit a bit disappointing. FIrst, no Blu-ray? Seems short-sighted given that standard DVD's are the Beta/VHS tapes of the 21st century.
The USB port does have one very good use. I've ripped a lot of my old CDs to MP3. I loaded 998 tracks (my older Jensen unit will only play USB sticks with up to 999 tracks - don't know about newer models) onto a memory stick and I have it plugged into my Jensen. I usually just shuffle but the TV can be used to select particular albums.
And given that the USB port on the Jensen is directly above the fridge, it's basically useless, unless you have a long USB cable or a holster to mount next to the unit. And frankly, who want's that? Like to have my phone with me or at least sitting around, rather than teathered to the wall.
Anyone have an idea on sun reflectors for the front and rear windows, similar to those we use in our vehicles? Maybe reflective film that doesn't mess up the views? Looking at options but throwing it out. Seems it would cut down solar radiation into the unit.
Excellent tips! You folks are awesome!Marceline said:I don't think that there much out there on the market in the way of 12v all-in-one units with a bluray player. Maybe because of the shift to streaming services.AirBoss said:
NITS:
OK, not really bad in the grand scheme of things but had to keep the Clint Eastwood theme going. I'm a bit of an audiophile and found the Jensen unit a bit disappointing. FIrst, no Blu-ray? Seems short-sighted given that standard DVD's are the Beta/VHS tapes of the 21st century.The USB port does have one very good use. I've ripped a lot of my old CDs to MP3. I loaded 998 tracks (my older Jensen unit will only play USB sticks with up to 999 tracks - don't know about newer models) onto a memory stick and I have it plugged into my Jensen. I usually just shuffle but the TV can be used to select particular albums.
I used Reflectix to make window covers for storage and the road. If you want some shade over the windows while camping, many of us have fabric awnings. Here's a source if you don't want to make them yourself: https://www.etsy.com/shop/ShinersView?section_id=19972582
Yes, 4K and 8K tech are awesome. The DVD issue WAY down the list but it, along with Blutooth issue makes me think the unit might be DOA. @AirBoss it's likely that your black water flush was not installed correctly. A number of 2020 400 owners have had the same issue, including us. Best guess is that the check valve in the line was installed backwards and water can't flow into the black tank. Apparently it's not a DIY fix so you'll need to return it to the dealer for repair. We need to get ours in before spring returns to Ohio.
ontheroad said:@treefrog...the last Jensen unit I saw didn't have a DVD player on it also...and that was last week at the factory...yes streaming is the norm now
Does anyone know which model it is?ontheroad said:@treefrog...the last Jensen unit I saw didn't have a DVD player on it also...and that was last week at the factory...yes streaming is the norm now
Maybe you can find a small portable DVD player with an HDMI out. I don’t own any DVD discs so instead I download a couple of movies from Netflix to an iPad before I hit the road.treefrog said:The stereo is a Jensen JWM20.
I would prefer to play DVDs and stream. I have a limited number of movies that can be stored on my phone at a time. Where we camp cell service often does not exist. Also we camp during the off season and its dark early, so we like to watch a show.
Hi @AirBoss. Congratulations on your trial run. I am new to towing and RVing (as of November 2019) and find this Forum extrememly helpful.
Will be installing an A/B coax switch so I can connect to park cable or use OTA HD antenna with little effort.
