FInally got an opportunity to get the 2020 T@B 400 out for a spin this weekend. I'd welcome imput from all you T@B'ers and perhaps some of this may help others who are new to this community, like I am. After all, seems to me that's why we're on here! Please keep in mind it's a check out ride and that, yeah, these are all First World Problems.
NODS:
All in all, it's all good. Obvious nuCamp put a lot of thought into this unit.
Rock solid construction, top-shelf materials and workmanship. Connections for power, water, sewer all went well. Did notice the shore water connection was bit tempermental and a bit difficult to tighten given how close it is the fill for onboard H2O. NOTE: if you use an inline charcoal filter with a pressure reducer (highly recommended BTW), make sure you let it run for a minute or two BEFORE you connect to the trailer, otherwise you're pushing all that charcoal thru the trailers H2O system.
Dinette conversion was very easy. Shower/bath performed as expected but more on that in a minute. Range is fairly powerful, though an autolight would be welcome. Easy to clean, tho. Fridge ( I have the large 3-way) worked flawlessly in gas and 110V. Sink is fairly easy to work with, tho I'd welcome a removable faucet head so you can spray down the sink as a handheld.
Microwave worked as expected. Storage and cubbies are well placed and serviceable. Bed was awesome! I did add a 3" Temperpedic-type pad but even so, it's a dream.
FWIT, my RV storage folks are awesome. It's "valet" in that I call a day ahead and they stage the rig, fill with H2O, start the fidge, fill propane, and all the usual prep stuff so all I have to do is show up, hook up, and out the gate I go! Towed rock solid behind 04 Tahoe Z71 without anti-sway bar.
NITS:
OK, not really bad in the grand scheme of things but had to keep the Clint Eastwood theme going. I'm a bit of an audiophile and found the Jensen unit a bit disappointing. FIrst, no Blu-ray? Seems short-sighted given that standard DVD's are the Beta/VHS tapes of the 21st century. This Jensen does not have a "DVD" setting in "Mode." So, you load the disc and supposedly it recognizes that and switches to DVD. Not so much. Had to reboot the unit several time, load, reload, then reload again at least 5 times until it finally loaded the disc. Kept showing "Loading" but nothing, even after 60-90 secs.
Will be installing an A/B coax switch so I can connect to park cable or use OTA HD antenna with little effort.
Why have three "Zones" but Zone A powers all three zones? It takes just as long to wire the unit with three zones during contruction that it does to tie all leads to Zone A. Yeah, I know...there's a fix or two out there on this forum but just questioning why not wire it properly from the get go. Bigger issue, the Blutooth was a disappointment. More often that not, my Samsung S-10 woud not pair, even after removing my phone from the Jensen and removing the Jensen from my phone...essentially starting over. Still, no joy. As I write, it will not pair. And given that the USB port on the Jensen is directly above the fridge, it's basically useless, unless you have a long USB cable or a holster to mount next to the unit. And frankly, who want's that? Like to have my phone with me or at least sitting around, rather than teathered to the wall.
Noticed the front and read windows do not line up correctly. Rear window: bottom latches (red buttons) line up OK but a couple side latches either don't reach their target...they come up short by 1/2in or so, or are so tight to the clasp that the latch goes behind the clasp. Front window is even worse: Bottom center latch doesn't reach it's target at all; trailer left side one is too close to target and ends up latching behind the clasp; one on trailer right doesn't reach its target.
Tricks to keeping the lid/seat to the head up with the curtain gathered behind it? Tried a couple things that worked OK but not 100%.
Learned that sliding the shower curtain by pushing it along at the very top is better than trying to close the curtain using the curtain itself.
And yeah, what to do with the fifth dinette cushion when in dinette mode. Back of my Tahoe is likely spot.
Didn't have the occassion to try the Air8 A/C unit but as we know, there's more on that elsewhere on this forum.
USER ERROR! Note to self (and others), be SURE to move the sink faucet AND the hot/cold tap all the way down into the sink before you close the lid. Got lucky in that the GF stepped into the trailer and opened the cover to find a FULL SINK and still running! Yikes! Overflowed just slightly. So, we got a chance to flush the gray water tank! Whew!
Fully expected the Black Water Flush to exit back thru the sewer line given that the directions say to ensure the valve is open. Where exactly does that water go? ;-) Again, likely user error.
Anyone have an idea on sun reflectors for the front and rear windows, similar to those we use in our vehicles? Maybe reflective film that doesn't mess up the views? Looking at options but throwing it out. Seems it would cut down solar radiation into the unit.
That's it for now. As I said at the start, all in all, a very nice rig and looking forward to wearing this thing out!!
Cheers to all and hope you can "Get Out There!" as often as you wish!
San Diego, CA
www.airbossone.comhttps://fineartamerica.com/profiles/owen-ashurst/shop1 ·
San Diego, CA
www.airbossone.com
I use the 5th dinette cushion as a “headboard”, tucked between the bed and the bottom of the wood trim. It works for me.
I used Reflectix to make window covers for storage and the road. If you want some shade over the windows while camping, many of us have fabric awnings. Here's a source if you don't want to make them yourself: https://www.etsy.com/shop/ShinersView?section_id=19972582
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
I recently read that Blu-ray is the Betamax of this century. Amazing advancement in technology, but not enough industry support and followers to survive...
We stream, or DVD. The screen is only 18" or so! (But then, as a 'phile, your ears are probably better than mine!)
Reminded of walking into very small Radio Shack in very small town ear acreage I'd moved to years ago. Asked for something faster than Dial-up ((was working in hi tech biz at the time). She looks up from her book, pulls her glass down on her nose and deadpans, "You have to remember where you moved to and WHY you moved here." Big slice of humble pie, right there!
Thanks for heads up on taglines. Working from my phone so didnt have biz on that.
Cheers!
San Diego, CA
www.airbossone.com
@AirBoss it's likely that your black water flush was not installed correctly. A number of 2020 400 owners have had the same issue, including us. Best guess is that the check valve in the line was installed backwards and water can't flow into the black tank. Apparently it's not a DIY fix so you'll need to return it to the dealer for repair. We need to get ours in before spring returns to Ohio.
TV 2018 Toyota Tacoma TRD Sport 3.5L 4WD with Firestone air bags.
MODS: BMV-712 battery Monitor, MPPT 75/15 Charge Controller, Fantasic Fan PWM control
Central Ohio
San Diego, CA
www.airbossone.com
Central Ohio
San Diego, CA
www.airbossone.com
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
But then again, I'd really rather read a book. It's much quieter!
If it's this one, it actually might be an improvement. Why? Because it has an HDMI input on the front. I'm not 100% sure but this probably that you could plug your iPhone, iPad, laptop into the Jensen and the video signal would go to the TV and the sound signal would go to the speakers. In the earlier devices you can plug your device into the TV via HDMI but there's no way to get sound to the speakers.
I would prefer to play DVDs and stream. I have a limited number of movies that can be stored on my phone at a time. Where we camp cell service often does not exist. Also we camp during the off season and its dark early, so we like to watch a show.
San Diego, CA
www.airbossone.com
2019 Tundra Crewmax aka Hoss
SE Louisiana
San Diego, CA
www.airbossone.com
You may have an idea already for the A/B coax switch, but if you don't, @Dalehelman had a writeup Titled "Roof mount digital TV antenna" that has wonderful, easy to implement ideas. @atlasb also contributed to that thread with ideas for the 400. I installed the antenna and Cable/Antenna switch and am very happy with both.
My Jensen DVD player does load the DVD automatically. It also pairs with my Pixel 3 pretty effortlessly (I'm no pro) so it's possible yours has an undesigned flaw in those departments.
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
The pinhole reset next to the "Menu" button seemed to work. Bluetooth works and DVD launched. Time will tell.
And I agree...this forum is a great resource!
San Diego, CA
www.airbossone.com
Are you actually holding the "Pair" button down while your phone is trying to pair? Also heard that cancelling all paired devices and staring from scratch helps.
San Diego, CA
www.airbossone.com
