Contoure Air Fryer Microwave
Amazonica
Amazonica Member Posts: 151
edited February 2020 in Modifications & Upgrades
After watching a video on the Avia trailer and seeing it's built-in Contoure multi-function Microwave, I wondered if that would be a substitution that could work in the 400. I can't use the microwave on battery power anyway, so I'm thinking the 1500W (12.5 amps) cooking draw would be ok on shore power? My current High Point Model EM925AQR is 1350W/900W. Haven't taken measurements yet. Looks like the Contoure only weighs 1.5 lbs more.
I need the experience and knowledge of the great folks on here to see if that's even a safe option before I pursue much more research. As a fulltimer living in my 400, I struggle with space for stuff and adding weight to tow around. Price is prohibitive, but I can justify it if I'm cooking/baking healtier meals at 'home'. Any thoughts?
https://www.contoureusa.com/copy-of-rv-185b-con-1
2020 T@B 400 BD w/Solar, Microwave and Closet
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
  • Denny16
    Denny16 Member Posts: 5,430
    An “air fryer” is basically a convection type oven (heat with blower) added to the microwave function.  How often would you use a convection oven and what will it add to your meals that a micro wave does not?  As for heather meals, a small crock pot slow cooker might be a better option, requiring less energy per minute.
    I lived full time for several years in a small Kenskill trailer, that had an oven, which I hardly used, I found I could cook several meals while at school in the slow cooker on low, and come home to a hot meal.  I turned my gas off when I was not actually aboard my trailer for safety reasons.  Also you can not leave a stove/oven cooking on its own, like you can a slow cooker.
  • Amazonica
    All good points @Denny16. Just something I've been thinking about.
    I'm not much of a chef, but really miss my oven cooked pizza and muffins. Micro is not the same for that. Also miss my jet-soaking tub, but hey, you can't have it all.  ;) First world problems. At least I have my freedom.
    When I had a a sticks-and-bricks home, I had a crock pot. Rarely used it, but I did use the oven.
  • Denny16
    Another another outdoor cooking option that will make a pizza and more is a gas fired Skittle, kind of like a low dish shaped steel cooking surface, with a lid (to make it like an oven) over a propane gas burner.  I am looking into getting one of these.
  • Amazonica
    Thank you. I appreciate all of the ideas.  :)
  • atlasb
    atlasb Member Posts: 584
    We carry a smaller convection oven and have made muffing, etc with it.  Usually carry it in the closet floor.  Also have a George Forman grill and use an Induction cook plate.  Do not use the propane cook top.  The microwave is probably the most used for us.  Several use the small Instant Pot type cookers.
  • Amazonica
    Thank you @atlasb. I too use my microwave most and save the propane for boondocking. Refilling/lifting the tank is a pain. I appreciate all of the ideas!  :)
  • rh5555
    rh5555 Member Posts: 538
    To answer your original question, you could absolutely replace the High Pointe microwave with the Contoure microwave / convection oven if there is space for it.  There would be no issue regarding the electrical supply, it is adequate for either unit.  Let us know if the switch can be done, we'd like to do it too!  Can't bake bread in a microwave...
  • Amazonica
    Thank you @rh5555. :) I've researched the dimensions, and the Contoure is a bit bigger, mostly deeper. I'm heading out so may be awhile before I get to a place where I can pull out the Hot Pointe to verify 'extra' space - if any exists, and update.
    I'm not stuck on the Contoure model of convection/air fryer/micro.
  • ontheroad
    ontheroad Member Posts: 489
    I'd keep the current microwave...we have it in our T@G and love it.... for baking I take my 3 qt. instantpot along with us...homemade banana bread...yummy
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
  • Amazonica
    OOOOhh that looks good! I've heard of instant pot, and goggled it, but it appears there is more than one, or knock-offs. I'm hesitant until I see one in person.
  • VictoriaP
    VictoriaP Member Posts: 1,496
    This is the “real” Instant Pot, in the smaller 3 qt size most appropriate for a solo RVer. https://smile.amazon.com/Instant-Pot-Duo-Mini-Programmable/dp/B06Y1YD5W7/
    I have the 6 qt at home and love it for making meals I can portion out and freeze for homemade TV dinners (which I do take camping), but storing them for longer term requires a decent size freezer. The 3 qt is a better option for a fulltimer.
  • Amazonica
    Thank you @VictoriaP that is helpful to see it and know which one.  :)
    In my 'previous' life, I liked to prepare and freeze portions. Harder now. My freezer is the szie of a single TV dinner. I do keep an ARB fridge/freezer in the Jeep on freezer mode, but only when on shore power.
  • ontheroad
    @Amazonica as@VictoriaP said this is using the "real"  3 at. instant pot...it uses 700 watts of power..Frank and I can make a meal in it and have enough for our meal and maybe another serving after that...and I find using ziplocs to store our leftovers takes less space than a container...imagine stuffed peppers, lasagne and I made chili last night...yummy!
    Ontario, Canada
  • Amazonica
    Yum! I like having options...
  • Tundra57
    Tundra57 Member Posts: 640
    Anyone tried the ovens you can get to put on a gas stove? Bit like a donut with all sorts of accessories. Supposed to be able to bake with it. I did buy the toaster plate where you can stand up four pieces of bread to toast. It works reasonably well. But I do have a mini electric toaster which works better.
  • Verna
    Verna Member Posts: 6,876
    @Tundra57 it is the Omnia oven. Works great. After my recent move I can’t find mine😩
    pthomas745 Administrator, Moderator Posts: 4,667
    @ontheroad I've tested my 3 qt Instapot with a Kill-a-Watt electricity usage monitor.  It only uses those 700 watts while coming up to pressure, which might only take 7-10 minutes.  After the unit pressurizes, it "cycles" for just a second or so every 15 seconds to keep the pressure on.  After the initial pressurizing, it hardly uses any power at all.
    I tossed my rice cooker and slow cooker after getting proficient at the thing.
  • ontheroad
    @pthomas745..I use our microwave for rice cooking since it's onboard already (currently T@g owners)...but stopped bringing the old slowcooker...love the instant pot when road tripping...thanks for the info!
    Ontario, Canada
  • Tampakayaker
    Instant pot, is a fancy electric pressure cooker with added features (yogurt, slow cook, etc).
    The latest "in" appliance is the Ninja Foodi which is a pressure cooker with multiple features including air fry.
    The other new thing is the Ninja Foodi grill which air frys, bakes, roasts, and grills up to 500 degrees.
    Tampa FL
  • atlasb
    Just got the Instant Pot Duo mini 3qt from walmart,  $59.92.   Got it all clean and ready to run the first test with the 3 cups water.  No Go.  The lights all light up, error message tells me it has a faulty sensor.  30 minutes on hold to instant pot, finally got live person,  told to take back to retailer and swap out or go through all the paper work for warranty.  Looks like a good product,  The swap had better work or will not be happy.  Not WalMart problem,  but not the way to start the new product.  Will drive the 60 miles to hopefully get a good working unit!
  • ontheroad
    @atlasb..hope it gets resolved..and that your next pressure test is good...made chili the other night in our 6 qt....now to try that recipe again halved..it was so good...
    Ontario, Canada
  • VictoriaP
    Would you be willing to share the recipe?
  • ontheroad
    @VictoriaP chili or the banana bread...or both..? 🙂
    Ontario, Canada
  • Denny16
    Both please!  Thanks
  • ontheroad
    @Denny16 @VictoriaP @atlasb
    https://www.dinneratthezoo.com/instant-pot-chili/   I made this in a 6 qt instantpot....have yet to try it halved, will look for my banana bread..lol.too many recipes!
    Ontario, Canada
  • ontheroad
    @Denny16 @VictoriaP @atlasb https://recipes.instantpot.com/recipe/banana-bread-royale/
    and here is the link for the banana bread..there was too much batter as I decided to use the bundt pan...so I also made a smaller one in another pan...of course I carry more than one cooking pan for the instantpot! Enjoy
    Ontario, Canada
  • VictoriaP
    Thanks, @ontheroad! Looking forward to trying these!
  • Denny16
    Yes, thank you 😊
  • atlasb
    ontheroad , Thanks so much for the recipes. The new replacement Instant pot works great.  Did a Hawaiian Pork meal and turned out OK.  Thanks again,  Fred
