Hi All,
I'm in the market for my first trailer and after visiting two dealers (one Bushwacker & other the TAB) I clearly noticed the quality difference of TAB and now I'm drooling at the thought of owing the one. Here is my dilemma. My local dealer in Madison, WI has some nice used trailers and the new ones with the central AC. This option seems like a big difference to me but I have no basis other than logic. So please help answer the question...? Is the central AC under the mattress and not above worth the extra cost?? Thank you!
Nick
If it were me I would purchase a nice used 320 and save my money for accessories and mods.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
One MAJOR difference: the newer under dinette AC models use up the largest single storage space in a 320, the only place big enough to store things like chairs, outdoor side tables, awnings and the like. The 2019 even had an outside compartment door standard in order to access that area, and I use it all the time. Storage was already very limited on these units, not a chance I personally would have sacrificed all that space for an AC unit that is only marginally quieter at best.
Also consider how you like to camp. AC is useless unless you have power. If you’re boondocking all the time, you may rarely use it. Mine hasn’t been turned on since I tested it the day I brought the trailer home.
We LOVE our 2018 320, and have never actually turned on the AC despite camping up here in MN, WI, and MI, even in 90+ degree weather. The vent fan gets a good breeze going and in all but the worst heat domes up north here, the sleeping weather is fine. We camp almost exclusively in state and national forest campgrounds, where there are very few sites with hookups and the ones that are need to be booked way in advance, so we almost never have electricity that others have mentioned is required to run the AC. We are weekenders, mostly, so if it’s utterly disgusting out (100+) we usually just stay home - if the plan is to spend all day indoors anyways, we might as well do that with a more comfortable sofa.
Odessa, Fl.
There are some really nice upgrades in the 2021 and the Nautilis water system with the very simple winterization setup, the low power DC style fridge, the more spacious bathroom, plus the cleaner exterior look with fewer vents and other interruptions in the look make the 2021 model very special. There was also a change to the trim which should bode well in colder climates.
I found the Air8 under the bed unit quieter, tho didn't do a Db test. Not a big fan of A/C but its a nice to have for sure.
For me, and FWIW, having the AC out of sight is a good thing. Didn't look at 320 too much as I wanted the larger rig. Got a "new" 2019 with slight cosmetic issue (scratches above exterior storage on psgr side), which dealer agreed to repair, and did well. Ended up getting it for about same cost as brand new 320S BD. So, there are deals out there if you're patient and do your homework. Good luck in search...assuming you haven't already purchased.
San Diego, CA
www.airbossone.com
