Anybody added the lid ram to an older 400 that just came with the cable stay?
Looking to get the parts to do that and mod my 2019. Part number for the ram and the mounts?
Photos of a 2020 or newer showing how and where the ram is mounted would be appreciated too.
0 ·
One (1) Part # 56004267 (the prop itself)
These are the nuCamp part numbers so your (or any) dealer can order them from nuCamp.
There was an earlier discussion about mounting this but here are the photos I uploaded
The way to install the gas lift is to center the bottom bracket and attach it, install the gas spring to the bottom and top brackets, then see where the upper bracket lands on the lid and mark it. Remove the upper bracket from the strut and attach it to the lid, then reattach the strut. I used stainless steel bolts and nylon locknuts.
Looks like an easy DIY with a drill.
Rest of mods are in this photo, dual tank brackets and a screen back, plus I had the Fab shop move the tub back to close what I thought was a pretty large space between tub and trailer.
They didn't come with my order. However, Lowe's, Home Depot, or any hardware store will carry them.
@N7SHG_Ham
It really is an easy install--except it is a bit awkward holding a backup when tightening the bolts.
It seems strange that they would sell something and not include the attaching hardware. I suppose they are thinking you must be ordering a replacement arm and would already have the nuts and bolts. By the way, I used stainless steel nuts and bolts and used nylon lock nuts just to avoid having to tighten the nuts every so often.
It does seem counter-intuitive for nüCamp not to include the hardware. Barb at Missouri Teardrop Trailers told me that they have ordered parts in the past from nüCamp for their own use and they too have not received the hardware (because they didn't specify to include those parts.) I guess nüCamp just takes the order literally and only ships exactly what you asked for (i.e., the part numbers you provide.)
J
Jeff & Amy
