How does one monitor the charge rate of the batteries from the solar panel? Does the T@B 400 come with a battery monitoring system, or is that something I need to add. I see several posts about the Victron; does that monitor overall battery charge, charge from the solar panels or both?
2020 T@B 400 BD Lite
0 ·
They currently are not installed as a standard device at the factory. You can request they add it after the trailer rolls off the assembly line, this is done at an extra charge and last I heard you need to buy it and ship it to nucamp for this service.
Many folks here like victron and they put out very nice systems, but there are cheaper options. All though the new Victron Smartshunt was only $133 bucks which was significantly less than their previous offering the BV712 which was around $225
Well worth adding.
When you are down there looking for your solar controller, you should be able to spot the battery, too.
My battery is under the center bunk space, with the inverter and main fuse buss against the front panel, so located the shunt in that space and closed it off from the rest of the storage area with some birch ply. This kept the wire runs very short. Here is the monitor location:
i like the idea of having the monitor, just not sure how I would mount yet.
2013 Tundra TRD 5.7L
Massachusetts
Massachusetts
Massachusetts
The harness from the shunt to the gauge is pretty long so you shouldn’t have an issue with the new location.
Massachusetts
victor
Massachusetts
Massachusetts
