Loosing glycol at auto bleeder assembly
I’m having problem with alde system. I’m losing glycol through automatic bleeder assembly drain tube. It is a noticeable drip of glycol and continues till reservoir is empty or is powered down. I try and keep level in reservoir just above minimum level cold. Do I have an airlock in the system? I’ve tried raising and lowering front of trailer with no change. Will I need to use manual bleed screw? Has this problem happened to anyone else? I’ve contacted Alde but with Coronavirus stopping work except essential services I don’t know how long I might have to wait. Any help is appreciated.
