I picked up a Vmax SLR155 for our T@B 320. Our's already has the factory solar and the Victron 75/10 controller.
The standard battery was a group 24 regular flooded battery, Do I need to monkey around with the Victron controller settings for this new battery?
0 ·
So far so good, but I'd love to hear if those 14.65 and 13.90 values should be tweaked.
The Victron Smart Solar manual says that default Absorption Voltage = 14.4 and default Float Voltage = 13.8.
So I think I'll just leave everything as is, that should work from what I can tell.
Darn these solar panel manufacturers nowadays for making such efficient units. It used to be you would consistently get half the spec value off a panel, but in the last few years some panels are now producing close to or even over the advertised power level.
(says it's for a Gel Victron Deep Discharge battery)
Absorption Rate 14.4
Floating Voltage 13.8
Equalization Voltage 16.2
Automatic Equalizer Disabled
Here is a link to everyone's favorite Will Prowse
https://www.youtube.com/watch?v=C-k0WHJ4RxQ&ab_channel=DIYSolarPowerwithWillProwse
Brad
Concord, NC
