RV Antifreeze left in water line?
With the present stay at home order, my 400 is still winterized (not the fresh water tank), at what point, or is there a need to run water through the plumbing lines?  We still have had, believe it or not, sub 32 temps here in North Iowa. Even if i did flush the lines, i have no where to empty grey tank, as everything is shutdown. I could just dump it, as there are no harsh chemicals.
2018- 400- Colorado V6-Marin MT bikes :)
  • jrhameljrhamel Member Posts: 101
    We are  in the same boat in southern Wisconsin with freezing temps at night. I'm just waiting until there are no more forecasts for freezing temps. Looks that will be very soon, end of this week.
     20 T@G XL Boondock and 2019 Ford F 150 4x4
    Madison, Wi
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,062
    @boonie, your post is not clear regarding how you winterized (AF in lines vs only in traps), either way, just wait until threat of freezing is over before flushing then dump the antifreeze laden water into a sanitary sewer connection.  Once you flush, then sanitize.
    Or dump it into a bucket (like a 5-gal paint bucket with a lid) for disposing the stuff later, or dump it down your house drain.
  • boonieboonie Member Posts: 83
    great idea, the answer i was looking for, thanks denny :)
