Color Emblem
RZRBUG
Member Posts: 890
Since the little T@B emblem next to the door had begun to lose some of its silver color, I decided to take it off and repaint it. But, instead of painting it the original silver color, I thought I'd paint it to match my trim color. Here is the result.
I removed the emblem by taking a length of strong fishing line and working it behind the emblem and sort of sawing back and forth while applying pressure from side-to-side. It left some of the original backing, but that's OK as it gave me a guide to reattach. I used a small bead of caulking to stick it back on with. Too much caulking will squirt out from the sides and leave you a mess to clean up when you apply pressure.
Lookin' good Larry! Nice touch too!Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
Perfect! I like the fishing line idea to remove it. I'll have to remember that trick.
Forgot to mention that you will need to lightly sand the surface of the emblem for the paint to adhere well, then clean with alcohol. Be careful with it as it is made of plastic and could easily break, especially when removing it from the trailer.
Nice!Judy and Mike - Central KY 2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 32
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
