Color Emblem
RZRBUG
RZRBUG Member Posts: 890
edited June 2015 in Tips & Tricks
Since the little T@B emblem next to the door had begun to lose some of its silver color, I decided to take it off and repaint it.  But, instead of painting it the original silver color, I thought I'd paint it to match my trim color.  Here is the result.
I removed the emblem by taking a length of strong fishing line and working it behind the emblem and sort of sawing back and forth while applying pressure from side-to-side.  It left some of the original backing, but that's OK as it gave me a guide to reattach.  I used a small bead of caulking to stick it back on with.  Too much caulking will squirt out from the sides and leave you a mess to clean up when you apply pressure.
Happy Trails Y'all
States Visited Map
