Window sealant
Michael49
Member Posts: 140
After doing a bit of a search here this seems like it may be a bit of a loaded question
, but I want to apply some sealant around the windows in my 400. I use lap sealant on the roof, but I don't think my grey lap sealant will look very appealing around the windows - something black or clear would be preferable.
I was considering Geocel RV sealant....
https://www.amazon.com/dp/B001FC98X2/?coliid=I1KZK84GEZ9GHN&colid=1VP0Q3Q7C77XD&psc=1&ref_=lv_ov_lig_dp_it
or 3M 4200.....
https://www.amazon.com/dp/B000Y8499G/?coliid=I36GKI54A37WB0&colid=1VP0Q3Q7C77XD&psc=1&ref_=lv_ov_lig_dp_it
Any other suggestions?
, but I want to apply some sealant around the windows in my 400. I use lap sealant on the roof, but I don't think my grey lap sealant will look very appealing around the windows - something black or clear would be preferable. I was considering Geocel RV sealant....
or 3M 4200.....
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.
Are you having leak problems? The window gaskets (at least in my 2019 400) do a pretty good job keeping water out. Adding sealant might just cause a problem rather than forestalling one.0
@Michael49, check out this thread “Caulking Guide”. A 320 owner near the bottom discusses window caulk.
https://tab-rv.vanillacommunity.com/discussion/comment/132384#Comment_132384
You might be right, it may very well be unnecessary - my concern is that starting at the end of the Summer will plan to do some long term traveling in our 400 (6-12 months) and a having a leak when its our primary residence seems like it would be unpleasantfalcon1970 said:Are you having leak problems? The window gaskets (at least in my 2019 400) do a pretty good job keeping water out. Adding sealant might just cause a problem rather than forestalling one.
- so trying to do everything I can to avoid this. Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.0 -
@Michael49, I had my T@B S Max (forerunner to the 320) for 3 years with a lot of time spent in Arizona. I’ve had my 400 for almost two years, living full time in it for 18 months and 6 months of that was in Arizona. It’s only been under cover for two weeks (It was snowing when I moved into my new house and I never got around to putting the cover on).Knock on wood, no window leaks in 5 years.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”1
- 427 Service/Maintenance & Recall Notices
