Does NuCamp use "Balance Beads" ?
B0atguyB0atguy Member Posts: 241
Hey all,
Just finished doing a boondock axle swap over on our 2019 320s this weekend .
When rolling the loose tire/wheels around the shop , I heard some distinct noise coming from inside the tires/wheels .
If I am not mistaken , they appeared to sound like "balancing Beads" used to balance tires . I did not notice any wheel weights on the wheels themselves, so I am assuming NuCamp must a type of "Balance Beads" .
Can anyone confirm they do and/or know what brand of "Balance Beads" they use ?
Inquiring minds want to know !
Thanks !!!
2024 NuCamp T@B 400 BD,  Charcoal / White
    How did the axle swap go?  Not much of a job is it.  Don't know for sure but don't think NU Camp builds the wheel/ tire up.  Think they get them that way.  our 400 came with a tire warranty from a vendor so, they probably build the assembly.
    I run Dyna Beads from http://www.innovativebalancing.com/mobile/
    I have them in my cargo trailer and my pickup, probably close to 200k on the pickup with zero lead weights.
    I was going to put them in the 400 tires, just haven't got around to it. I would be surprised if factory tires had beads, but they might. Typically trailers come without any sort of tire balancing.
    My 2019 TAB had about one-third cup of glass beads (looked like fine sand) inside the tire.  I assumed they were for balancing the tire but I'm not sure how much effect that small amount of small glass beads could have.
  • B0atguyB0atguy Member Posts: 241
    edited May 2020
    Thats a good call . Likely NuCamp is not building wheel / tire combos in house. Likely they are a premade set-up ordered in bulk .
    Axle swap went well, with no hick-ups . Hardest part was getting the old axle to "remove itself" from the conical locators !
    Yea, rolling my wheels/tires around , I distinctly noticed a sound inside that resembled beads rolling around ! Thats why I though the tires must have had balance beads in them .
    Most Boat trailer tire set-ups have no kind of balancing as well . NuCamp must want these high quality RV's to run down the road , nice and smooth !
    @B0atguy, my Boondock tires came from the factory with balance beads.  I confirmed that with a tire shop when they replaced my tire valves with high pressure valves.
    Good to know, I am surprised, but glad to know beads come in the tires.
    And yes it is just a few ounces like maybe five or six required in the size of a Tab tire. They actually work and work good. Tire rebalances every time you get up to speed.
