TerryV6
Member Posts: 1,101
I’ve never noticed ‘‘this before. We haven’t camped this year, but have the camper in the driveway, where my wife loves to go and read. I had the camper plugged to shore power. This evening I unplugged. We have our battery disconnect inside, to the left of the bathroom. That switch I put in 2-3 years ago, following a mod I found here. I turned that switch off too. We noticed that the back red lights outside are still lit. Any ideas? Did I miss something?
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
T@bbey Road
Appleton, WI
My wife had purchased a rubber cover for it and we always left the cable at a downward angle. I took the cover off and was surprised to find it was full of water. TaDa!! Problem solved. I’ll have to clean the connections of course, but now its lights out, somebody home. Thanks all.. PluncK!!! That’s the sound of the cover hitting the trash bin. 2 points!
T@bbey Road
Appleton, WI
Tampa FL
Although I initially suspected water on the 7-pin plug, the description of only those two lights being illuminated threw me off. That circuit should control all four side-marker/running lights (i.e., front and rear sides), the license plate light, and both of the tail lights. Although there is only one wire for those lights from the 7-pin plug, if you trace the connections from the junction box at the front of the trailer, there are two wires leading to those lights, presumably one wire to each side of the trailer. See the junction box diagram below for a 2019 T@B 320 S - - I am referring to terminal #3 with the green wires.)
So, why wouldn't ALL the lights on that circuit illuminate under the described conditions? Just curious.
I always just flop the trailer power cord downward to eliminate this issue and and condensation created. I noticed the condition above about 10 years ago when I swapped out incandescent trailer lights with LED lights and attributed it to a grounding issue on my 4-wide Little Guy.
PS:
I just tested our plug by inserting a U-shaped piece of 14 AWG wire between the 12V (11 o'clock) and Taillights (1 o'clock) contacts inside the plug, with battery switch on & trailer unplugged from ac power. All six running lights lit up (small front & rear side lights, plus the two large round taillights at rear). With battery switch off, none were lit.
T@bbey Road
Appleton, WI
Since you found that the seven-way plug had water infiltration, I can see it completing the circuit between the 12V and the running/tail light pins even if that plug were disconnected from the tow vehicle, BUT only if the trailer battery switch was on, or somehow defective, which would allow power through to the running/tail lights.
IF the seven-way plug was in fact disconnected from your tow vehicle, and your battery was also disconnected/isolated via the battery switch, then I would agree with @BrianZ that there is a good chance there is something defective with the switch that was allowing power to get to the junction box. (On the other hand, it sounds like getting rid of the water issue solved the problem, which tends to indicate that the battery switch was not the issue, assuming nothing changed as far as the battery switch and/or battery connection.)
Unfortunately, it is pretty much impossible to re-create the specific circumstances, but if your switch is good AND the seven-way plug was not connected to the tow vehicle, then there must be some "voodoo" magic going on. Very strange situation, but I sure am looking forward to learning what happened, if that can be determined.
T@bbey Road
Appleton, WI
Doesn't mean it isn't wired properly, but I'm just not sure where the red wires are connected inside the converter. It appears that the same wire is looping back in to where it starts, with a switch in between. Is it in fact killing the battery power when you turn it to "off."
This configuration means the battery is always connected to the pigtail (via the junction box) regardless of the position of the cutoff switch. Therefore, water in the plug could indeed route battery power to the running lights by creating a short between the battery and trailer running light circuits.
@TerryV6, I suspect your initial diagnosis was correct. However, why all the running lights were not affected equally is a mystery that remains a bit out of my pay grade! ;-)
Our switch in the tub will always protect the trailer battery when turned off, but it won't protect our TV battery from drainage by trailer if 7-way remains plugged in; because our 7-way socket is wired directly to the TV battery via a circuit breaker near the battery under the hood, so the outlet is always hot. Good thing it has a spring-loaded cover though. We would need to unplug from TV if stopped for an extended period of time, to protect TV battery from trailer usage, regardless of switch position.
As far as the trailer taillights shorting on, I would guess that water inside the plug has limited conductivity (unless there's enough dissolved salt), so the voltage may be low, which would further limit the current through the LED lights (which already contain a current-limiting resistor to prevent burning it up). If voltage/current is low enough, the LED will stop conducting & change his name to "NED" 😉. If other lights are using more LEDs with higher internal resistance, they may not turn on at reduced voltage, or the wiring may be longer & have higher resistance. Circuits are dynamic things that can easily get out of balance & malfunction under less than ideal circumstances.
T@bbey Road
Appleton, WI
As @ScottG points out, your switch currently cuts the power from the converter to the junction box at the front of the trailer, but it does not prevent the trailer battery from sending power to the junction box. Therefore, when water penetrated your seven-way plug, that created an electrical connection between the 12V and side-marker tail light pins on your seven-way plug. Since there is nothing (like a cut-off switch) preventing power from the trailer battery reaching the seven-way plug (via the junction box connection), the battery was the power source (because your switch is not wired to isolate the battery.) But, as we all agree, that doesn't completely solve the mystery you started with. (Thank you for providing the additional photos. That was helpful.)
