Victron did not power on
NoVaGuyNoVaGuy Member Posts: 95
Installed battery monitor today.  When I connected the head unit, it did not turn on.  I did have a spark when connecting the negative lug.  All other electrical devices seem to work.
any ideas?
States Visited Map
2020 T@B 400 BD Lite
    Never mind.  I am an idiot.  It’s working now.
    head unit not coming out of set up mode.  Seems to be working otherwise
    States Visited Map
    We all have our moments. 😁
    MuttonChopsMuttonChops Member Posts: 1,594
    edited May 2020
    LOL =)  trust me you are Not an Idiot.
    I get that title . . . an I was trained as an Engineer.
    Adventures:  51   Nights:  322  Towing Miles 41,200+
    Does it matter which side of the shunt goes to battery and which side goes to block?  I may have that backwards too.
    States Visited Map
    Don't know about your brand monitor.  However on the cheaper (price/quality/operation) China one I have it does matter . . . wiring backwards (on mine) just causes the Discharge / Charging data to be backwards, does not cause any failure issues.
    @MuttonChops so was I.  Had the wires switched.  Must have been due to working in the heat 🙄🙄.
     Seems to be working.  Have one odd reading I need to figure out.  Also need to figure out how to get the head unit out of set up mode
    States Visited Map
    4ncar4ncar Member Posts: 1,072
    If you complete the set up 9m your smart phone, 5he head unit will eventually catch up. Assuming g you have a Bluetooth enabled device...
    edited May 2020
    You guys are so reassuring... I wired mine the wrong way the first time too. Can't remember, but I think I did HOT to 'B' instead of to 'A'.
    The Victron did survive tho.
    I could never have been an engineer. I never admitted it. B)
    Head seems to have caught up.  Thank you for the help.  I am getting an alert about the midpoint voltage.  I will use the battery a bit before I worry about it.  May just be that the system is learning.
    States Visited Map
