Victron did not power on
NoVaGuy
Member Posts: 95
Installed battery monitor today. When I connected the head unit, it did not turn on. I did have a spark when connecting the negative lug. All other electrical devices seem to work.
any ideas?
any ideas?
2020 T@B 400 BD Lite
Never mind. I am an idiot. It’s working now.
head unit not coming out of set up mode. Seems to be working otherwise
2020 T@B 400 BD Lite1 -
We all have our moments. 😁
2 -
NoVaGuy said:Never mind. I am an idiot. It’s working now.LOL
trust me you are Not an Idiot.
I get that title . . . an I was trained as an Engineer.
Does it matter which side of the shunt goes to battery and which side goes to block? I may have that backwards too.
2020 T@B 400 BD Lite0 -
NoVaGuy said:Does it matter which side of the shunt goes to battery and which side goes to block? I may have that backwards too.Don't know about your brand monitor. However on the cheaper (price/quality/operation) China one I have it does matter . . . wiring backwards (on mine) just causes the Discharge / Charging data to be backwards, does not cause any failure issues.
Adventures: 50 Nights: 415 Towing Miles 50,6501 -
@MuttonChops so was I. Had the wires switched. Must have been due to working in the heat 🙄🙄.
Seems to be working. Have one odd reading I need to figure out. Also need to figure out how to get the head unit out of set up mode
If you complete the set up 9m your smart phone, 5he head unit will eventually catch up. Assuming g you have a Bluetooth enabled device...NoVaGuy said:@MuttonChops so was I. Had the wires switched. Must have been due to working in the heat 🙄🙄.
Seems to be working. Have one odd reading I need to figure out. Also need to figure out how to get the head unit out of set up modeTV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
You guys are so reassuring... I wired mine the wrong way the first time too. Can't remember, but I think I did HOT to 'B' instead of to 'A'.The Victron did survive tho.I could never have been an engineer. I never admitted it.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Head seems to have caught up. Thank you for the help. I am getting an alert about the midpoint voltage. I will use the battery a bit before I worry about it. May just be that the system is learning.
