I know everyone will be telling me its a waste of water. But any tabbers found a small clothes washer suiable for undies, a tee or maybe a pair of jeans.
Soaking in the sink would work. I have seen very low powered electric and some hand types.
Any thoughts?
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
2019 320 Boondock Edge - Sold Jan 2022
You put the clothes in, add water and soap, then close the bag and you almost knead it like bread for a couple of minutes. Then empty the water, add rinse water and knead, again.
I have found it to be a very effective means of hand washing.
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
Giantex: $279: https://www.amazon.com/dp/B07HKXVQYC
or
Panda: $255: https://www.amazon.com/dp/B083G9WVNC
Those thing’s are great, and I could put it right next to the dishwasher. They are pretty cool though.
I already have a mid sized 50pint dehumidifier that has an advertised laundry dry mode. It's meant for all those small spaces where you only spin dry your clothes and hang them up to finish drying. So the Panda washer would pair perfectly with that.
Alternatively, I could just get a pair or two of underwear you only change once a year and never do laundry again...
https://www.indiegogo.com/projects/hercleon-kribi-the-world-s-cleanest-underwear
Bucket 1 was your wash bucket and you used the plunger to agitate.
Bucket 2 was your rinse bucket.
Bucket 3 was the spin cycle. It had a bunch of holes drilled into it. You then hung it from a tree with the rope, twisted it tight, then ran (unless it was hot and you wanted to get wet). It spun excess water out through the holes. Then you used the rope for drying line.
(The leftover water in the buckets was used to put out the nightly fire)
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
