Help! Air Lock?
I have a 2016 320 s. Had it for several years with no problems.
I filled the water tank to 80%. Turned on the pump. Faucet sputters and never stops.
Pump never stops.
Aldi gurgles when pump is on.
Tried raising and lowering the tongue. No luck.
I'm stuck.
Any ideas?
Mickey & Terri
2016 Max S
Kalamazoo Michigan
  • mandtmandt Member Posts: 158
    I tried city water and that works fine.
    Mickey & Terri
    2016 Max S
    Kalamazoo Michigan
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,956
    edited June 2020
    The city water connection would have cleared your lines of air.  Your pump is not able to pressurize.  Can be due to a loose or cracked pump filter housing, a loose pipe connection, a fresh water tank outlet obstruction.  Test the pump by removing the intake side and see if it can take up water from a bucket.
  • MischiefBrewingMischiefBrewing Member Posts: 30
    edited June 2020
    Continuation of what Sharon said.  When taking up water from a bucket, listen for gurgling.  That's how I knew I had a crack in my pre-filter on the intake side.  Had to remove the pump to find it.  I saw it sucking water out of the bucket but heard that it was still taking in air too, which meant a breach on the intake side of the filter.
