Overhead fan...
trimtab
Member Posts: 237
yeah, it's part of the air conditioning...
the slight (to me, not the other party ) needs to be fixed. In looking at the mesh cover and ring with a finger tab, is there a trick to taking that off? I have been rotating and pulling to no avail...any tricks to get it off in one piece?
yes this is almost...a superfluous problem..almost...
the slight (to me, not the other party ) needs to be fixed. In looking at the mesh cover and ring with a finger tab, is there a trick to taking that off? I have been rotating and pulling to no avail...any tricks to get it off in one piece? yes this is almost...a superfluous problem..almost...
the slight SQUEEKING2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E0
I think you mean the screen for the Fantastic Fan? You have to pull really hard.and you feel like you will break it, but you won't.
I wonder if it you have a loose screw in the fan or if it needs a bit of oil?2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Thanks jkjenn..I will try that! I gave up originally because I thought I would break it.2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E0
I had the same concern. I get it "Try harder."
2019 Tab 320 CSS, 2019 Ranger TV, OH0 -
If, like me, you are too chicken to "try harder" then a little gentle coaxing with a screwdriver or other small pry bar helps. Once you get the first tab to let go the rest are easier.
It took me four years to finally pop my screen off. If you are really chicken just set the fan to blow out on high for a few seconds and that will clear most of the crud. :-)2015 T@B Max S (320)
That is what I did. Bok, bok, bok!2019 Tab 320 CSS, 2019 Ranger TV, OH2
