Came back from boondocking and upon return the electrical system does not work on battery. I took the battery to Auto zone and the battery checked out fine. reinstalled the battery and still nothing on Battery mode in camper electrical system. Everything lights up in camper when plugged into electrical outlet and on electricity mode. I assume it must be a fuse or breaker - probably a fuse from battery to the rest of the trailer resulting in no power to the trailer. Is there a diagram somewhere indicating which fuse to replace first - I don't see it in the instructions provided by NuCamp
0 ·
You do have the battery switch turned to on, right?
First, in-line fuse holder at Battery positive terminal
Second, WFCO Power Center 30-Amp Battery fuse . . . Red Box in picture below
Third, WFCO Power Center reverse protection fuse (fuse below red box)
House fuses 1-6 have an LED that turns-on when the fuse is bad.
The Battery fuse (red box) and Reverse Protectin fuse do not have indicator LEDs
PNW
PNW
