OK, I read somewhere that one of the T@B owners put short pieces of hoses and a "Y" connector to connect the gray and black tank "exits" (I can't think of the correct term here), and I can't find the discussion.
Could you post a picture of how you did this, please? I asked a friend with a 43' Class A to show me what their hookups look like and the "Y" connector was built-in--looks really expensive.... I've seen the T@B tongue with black and gray tubes and I can't quite figure out what the "Y" connection looks like. And, do you keep the "Y" connector in place while traveling, or do you remove it after flushing the tanks.
Thanks for your help.
http://www.tab-rv.vanillacommunity.com/discussion/comment/7771
Thank you, Jen, Rad and BchBum. That makes sense.
Yes, leave gray water tank partially filled to rinse out black tank's residue in hose, and don't leave "Y" in place because it can be damaged in transit.
With the flushing unit in place you can put some water back in the black tank to help to rinse more out. Paul, my friend with the 43' Class A, reminded me that the water will never be totally clear when coming out of the black tank....a good thing to know, and will save some water and effort.
Empty gray water tank last to help rinse out hose.
Thank you very much!
Val and I will be in Yellowstone for a 5 night stay in Septemberw with full hook ups. With the Y connector I will not have to mess with the waste hose for the time we are there.
if it is a short stay without hookups there is no advantage to the Y. It would just complicate the trip to the dump station.
As for storage, I have a waste bin in my TV where the connector and two short additional hoses will be stored.
Believe it or not, I've never been inside a T@B and poked around, nor have I poked around on the outside, except seeing the gray and black pipes next to the tongue on a Sofitel. I wouldn't have known what it all meant without some of the lessons from here. Pictures have been telling me more than a million words
One thing to watch out for is disconnecting the hose and laying it down in the ground - depending on the angle it might discharge whatever is lurking in the hose back at you - saw some poor slob do this. I always raise the hose high and make sure everything has run out before lowering and connecting to the gray valve.
