@Polanskyster, are you referring to the aluminum tub on the front of the trailer, or some other storage compartment? I don't own a 400, but I would be surprised if there is no lock on a side compartment storage door. I did put one on my aluminum tub and can post photos if you are interested, but some folks don't like that idea, primarily because the propane tank is not supposed to be in a locked compartment (for safety reasons, and fire department access.) I only use it when my trailer is in storage, or when I am camping and am with the trailer, but otherwise I leave it unlocked while towing the trailer.
Actually, I forgot about it, but I previously posted those photos. They are near the bottom of this thread:
I installed locks on my tub because I have things in there other than a propane tank. The prohibition about locking propane compartments is an RVIA restriction not a state or Federal law. Some localities have restrictions about driving with propane appliances in operation. The bridge over the Houston ship channel and the Holland tunnel prohibit between NY and NJ it and I have heard the NY state thruways prohibit it also. I can understand it in a tunnel but on a bridge?
Bayliss, I'm referring to the small compartment door on the passenger side of the T@B400. There are 2 closing tabs but no lock. The items stored in the compartment are also accessible by lifting up the panel under the bed.
The outside storage is not accessible via the underbed panel on my 2021 T@B 400...That is a change from prior years afaik. But there is no lock on either the water access panel on the drivers side or the outside storage on the passenger side (which both use the same access door).
After two years of looking and considering...finally the proud owner of a 2021 T@B 400 Boondock! 2023 Honda Ridgeline RTL-E with Redarc Trailer Brake Controller
BirdieJane, Did you install the 7/8 size? I could not get the 7/8 or 5/8 to fit in my 2021 T@B400. Very frustrating and strange that a lock was not included.
I'm attempting to replace the non locking latch on the storage door with a tubular cam lock with a 5/8 cylinder from amazon. This lock is the smallest I could find. After removing the original latch I discovered replacement lock will not fit, its too large. Any suggestions on what I should do? I did not want to make the opening larger with a drill. Any ideas are welcome.
https://tab-rv.vanillacommunity.com/discussion/comment/118579#Comment_118579
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Portland, OR
That was his original question. Thanks.
cheers.
Portland, OR
The two tabs would actually make 14x9 if you were attempting to put a box in it
2019 Tundra Crewmax aka Hoss
SE Louisiana
RV Designer L327, Ace Compartment... https://www.amazon.com/dp/B007H2PF1I?ref=ppx_pop_mob_ap_share
aka BirdieJane towed by Quinn
Portland, OR
