Awning ?
You could cut those half circle slits in it to dispel the excess air like what some parachutes have. Or just go for the ride!DougH said:@Tampakayaker ; And when wind gets under the mylar tarp would there be enough lift to carry the T@B into a nearby tree top?2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
We we used a regular canopy over the top of our TaB in addition to shade cloth on both sides last summer at Asseteague. The shade cloth does help.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Former steward of a 2017 T@B S Max -
Someone needs to make an aluminet canopy and see the results. But, you are having great results with the black cloth!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I'm a new Tab 320s owner, and don't know what type of shade awning to buy. I've looked at some brands supposed to fit 320s, but they are pricey. Any suggestions?
@mert1984 there are many discussions regarding fabricating something on your own. Begin with using the search feature in the upper right hand of your screen and type in "homemade awning" which will get you started. Good luck.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
Have you looked at Marti’s awnings? We gave $120. for this one, it’s 6’ wide and 6 1/2’ coming out.
2016 320 CS-S 1954 Ford F100 2017 Chevy suburban 2023 Chevy Silverado 1500 -
We use a good pop up canopy with leg weights when we're staying more than one day somewhere. But one day overnights it's a little bit of a hassle. We also used to use the awning that fit the keder rail but found it to be somewhat of a hassle too. So for those multiple "one day stops" along the way to our final destination having something that can put up and taken down easy works best for us. We use what many others use...a 9 ft half umbrella but with a base with fold down legs. Attach adjustable guy lines to each end of umbrella and attach other end to the T@B handles then secure umbrella pole to door handle with velcro. Some even sow/velcro an extra piece to cover the gap between umbrella and the door. Very handy when don't want to spend a lot of time setting up after a day of driving or if winds pick up or storms roll in when you need to take it down quickly. Can do either in a minute. Ours has built solar lights too.
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
"Our favorite trip will always be our next one" -
A number of us seem to have the same Hasika awning: https://www.amazon.com/Hasika-Waterproof-Resistant-Multifunction-Traveling/dp/B00ZKYSCOM/It works best with some aftermarket extra-sticky suction cups to mount to the trailer roof: https://www.amazon.com/gp/product/B08N13T8X2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1An while it comes with poles, variable length tarp poles allow better flexibility for deployment: https://www.amazon.com/gp/product/B072K1B91Q/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1One thing I love about mine is that when it's extra windy or rainy, it's easy to stake one edge of the awning directly to the ground in a lean-to configuration that maintains a decent amount of sheltered space over the T@b door area:
Northern VA
2022 T@b 320 S / 2021 Subaru Outback -
There are a lot of different options. Keep your eye out here and in the T@B Facebook groups and you'll see people selling used ones quite often. I've been through three different styles and have yet to buy a new awning.mert1984 said:I'm a new Tab 320s owner, and don't know what type of shade awning to buy. I've looked at some brands supposed to fit 320s, but they are pricey. Any suggestions?If you search this forum for "awning" you'll see quite a few ideas.San Francisco Bay Area
A standard SUV awing has worked fine for us. Around $100 and sold under many brand names. Fits over the top and ties to the front and rear handles so no leaks and the door opens all the way.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
