2019 t@b 400 original design-went camping last weekend upon arrival the door under the refridgerator would not close-emptied out-don't see anything behind can't figure out how to get the drawer off so i can look better to make sure nothing is caught in there-anybody know how to take the drawer out or what might be causing the obstruction?-i figured something may have fallen behind from the top of the drawer-but only about 2 finger's space to see through-shined a light but hard to see-it stays about an inch from closing seems to be hitting something
thanks in advance for any suggestions
                0 ·
What you might find is that the catch at the rear of the drawer failed to 'grab' the back of the drawer. If this is the case, firm pressure on the drawer when it is replaced should resolve this.
2015 Nissan Frontier SV, 4WD Crew Cab
Manson, IA
Hope you got it off OK. BTW, if you ever need to replace the drawer mechanisms, you can find them at Home Depot. They identical to OEM slide mechanisms.
PS...don't ask me how I know.
https://www.homedepot.com/p/Everbilt-18-in-Soft-Close-Full-Extension-Side-Mount-Ball-Bearing-Drawer-Slide-Set-D94218E-ZP-W/302867519
San Diego, CA
www.airbossone.com
https://tab-rv.vanillacommunity.com/discussion/8774/help-appreciated-400-drawer-catch-issue#latest
nüCamp: 2019 T@B 400 Boondock Lite
