Anybody ever walk into the extended window next the entry door on a T@B400. I've done it a few times, it's right in the way during entry/exit. This time, hitting it from the door/forward side, It slide to the rear of the attachment track and the top right (forward) corner of the window broke off. I am disappointed, since I didn't hit it that hard. The sealing surface of the window still fully contacts the gasket but still disappointing.
You might try a product called "Bondic" to repair the window. It claims it is a chemical weld and not a glue. I have had success in some applications and less success in others. Since the window is a polycarbonate and fairly clear it might work well.
https://getbondic.io/offer-01/?lpid=895&utm_source=8580&utm_medium=bondic&utm_term=514&utm_content=&utm_campaign=0&aff_id=8580&camp_id=0&sub_id=bondic&req_id=68eb324f4aa24f38a97e5ead5e859472&contract_id=0&oid=514&device_type=PC&country_name=United+States
I only have two trips under my belt so far, but also discovered the head hazard of the kitchen window when it isn't fully deployed as high as it can open.
My wife had opened it about half way, which was the first time it had been left in that position, and I promptly ran right into it too!
Good luck with getting it fixed. Replacement is easy with these windows, but I imagine a bit pricey for the new one.
Now have a spare window for parts...
Southern California
Full-timer since 2019
Bondic works similar to what @tabiphile said about Weld-On 4 except it seems easier to use. Just run a line of bondic along the edge to be joined, put the pieces together, and then use the supplied UV light to cause a bond.
2022 Ford F350 Tremor | 2022 Cirrus 620
Southern California
Southern California
Yes, it's nasty stuff and you will have to ensure good ventilation.
https://www.tapplastics.com/product/repair_products/plastic_adhesives/weld_on_16_cement/132
https://www.tapplastics.com/index.php?route=product/product&path=69_123&product_id=608
Maybe you can pick some up if you make it further north this summer.
https://www.tapplastics.com/about/locations
