Hi, newbie just setting up for my first excursion with my 2019 Sofitel 320s. My 320 has factory solar with the Victron controller. I'm planning to swap the Interstate my 320 came with for a Battleborn 100Ah, for the available juice on a daily basis, charging flexibility, and to lighten the tongue weight (I moved my spare up there). So my question is, would this be a straight swap, or is there something I need to reset in the controller, and is the original converter ok or do I need a new one? I know there is a lot in here about this subject but after an hour of searching I've yet to find the answer to this specific question. Thanks!
0 ·
Sold 2023 Tab 400
Sold 2018 T@B 320S
AM Solar in Springfield may be a good resource for doing a proper install.
The Progressive Dynamics converter might actually damage LFP batteries. In the research that I’ve been doing it looks like it never exits absorbtion (14.6V) and basically attempts to over charge the batteries too often. This means you might need to disconnect power when storing your T@B. That isn’t something I want to deal with.
The Victron charges have ‘storage mode’ where they drop the charge voltage way down is they don’t detect a discharge load over 24 hours. Seems like the best solution to me, but they’re quite expensive. The 30amp Phoenix charger is ~500 bucks, the 50amp is $675 or more. The lower powered 25amp Phoenix charger is more reasonable around $300, but then you get a charge rate even lower than the stock WFCO. That might not be much of a problem if you have time to charge once you finally plug in.
2019 Toyota Tacoma TRD Off-Road
Seattle, WA
