Sound Mufflers for Air8 System
TNOutback
Member Posts: 633
Nosing around the Truma air conditioning site (the OEM for Elwell’s Air8), I noticed they have an accessory option advertised as a “sound muffler” for the ducting system. It claims that one muffler will reduce the noise by 50%, and two within the line would reduce the noise by 90% ! Very interesting idea; a UK-based site offers them for about $66 US equivalent. The Air8 can be quite noisy on the high fan speed.
https://www.truma.com/int/en/products/truma-air-conditioning/overview.html
Given how the Air8 is installed in the TaB400, I do not think their is any room for additional air duct “mufflers”, unless they are are flexible like the original ducts.
@Denny16 they are apparently supposed to be bent to improve sound damping. A section of ducting is cut out and replaced with the muffler.
Of course Murphy's Law states that in fine print somewhere it will say "reduces cooling efficiency by 25%".TNOutback said:I noticed they have an accessory option advertised as a “sound muffler” for the ducting system. It claims that one muffler will reduce the noise by 50%, and two within the line would reduce the noise by 90% !
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow) -
OK, thanks for how they are installed. Good luck.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
