How to replace licence plate bulb ?
2manyplaces
Member Posts: 20
Hi
We need to replace the bulb above the licence plate on our 2018 320s,
How do we do it please ? We have searched online and in the manual but can't find the information.
Thank you
Thank you
2018 320S
Vancouver Island.
Vancouver Island.
On our 2020 Tab 400 BDL, you remove the 2 screws that hold the light to the Facia to gain access to the bulb.Brad2020 400 BDL aka "Boonie"
Concord, NC -
Ok I’ve done this . The bulb is a sealed LED unit you can buy from Superbright LED order LPC-B-NW2 . It’s held up by 2 screws and the 2 wires should have some slack . Warning ⚠️ don’t pull too hard as NuCamp uses splice connectors which are not very strong. I called NuCamp for advice and they told me too pull it out , it came out and the mating wires could not be accessed through the 1/2” hole. When you take it down capture the 2 wires and cut them off against the housing which should give you enough wire to mate to the new fixture. You can use wire nuts to connect the wires , and electrical tape to secure nuts for safety. Or look up on the web TapCon connectors these I prefer.
In closing if you have to find the wires you will have to remove the hinged shelf across the rear, behind the seat back. It’s only held in place by a few square drive screws and the hinges .Let me know if you need clarification. Good luck
Thank you this is really helpful, will have another look.2018 320S
Vancouver Island.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
